PLEASE HELP - I think something is wrong with my car
Old Apr 7, 2008 | 06:37 PM
evanj5's Avatar
Exclamation PLEASE HELP - I think something is wrong with my car
I go to the dealership saturday and get an oil change. I also had a tech look at the serpentine belt tensioner because after installing the UR underdrive pulley I am getting what has been concluded to be belt noise.
OK so on to my problem. I noticed today that my revs have been spiking when I hit the throttle. Now some may ask well you drive a stick make sure the clutch is not fully unpresses. It is. I will be cruising at like 2500 rpm and hit the throttle and all of a sudden the rpms will jump up to 3000 and then go back down to like 2800 rpm all while under the same ammount of throttle. I does it a different times in different gears under normal or full throttle I dont know wtf would cause this.
Does anyone know what could cause this ?????
Old Apr 7, 2008 | 06:57 PM
evanj5's Avatar
After doing some reading I think a better way to explain the phenomenon would be surging. My engine is surging. Almost like the ECU is cutting the fuel slightly and pulling power from the car. Slight surges nothing drastic at least not yet.
Old Apr 7, 2008 | 07:00 PM
aznboi2424's Avatar
torque converter?
Old Apr 7, 2008 | 08:03 PM
evanj5's Avatar
Originally Posted by aznboi2424
torque converter?
I believe I just figured it out.
OMFG I cannot believe the dealership put that much oil in my F*CKING car!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Unbelievable.
Old Jun 27, 2008 | 12:15 PM
ITL's Avatar
ITL
I do my own work.
so your problem with surging was an overfill of the engine oil? I've had a very small surging issue for the last month or so. It feels like some sort of parasitic drag maybe every 20 seconds or so at very light throttle when cruising on the interstate...
Old Jul 14, 2008 | 10:16 AM
ITL's Avatar
ITL
I do my own work.
I took my car to the dealer a few days ago for the power steering and wiper motor recalls, and asked them to take a look at this. It turns out my surging issue is due to a bad accelerator position sensor.
Old Jul 14, 2008 | 01:02 PM
also known as TPS Throttle Position Sensor
Seems to be a lot of those failing these days---its the mileage we are all getting to~
Old Jul 14, 2008 | 01:04 PM
Note the UR and other brands of UNDERdrive pulley DO require a different sized accessory belt- the ac belt, than stock.
They are about $45 for the belt, and the pulley should have come with a list of brand names and belt numbers to use
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
SUPRMN84
Sep 2, 2015 11:50 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
