Planning to do oil change every 7k interval
Hi everyone, I have 2011 MDX Advance with 78600 miles on it. I had been using mobile 1 synthetic with OEM oil filter since the day I bought the car new with 5 miles on it. I have been changing oil every 3k intervals per the MID (around 10-5% of oil life). Now I am thinking I might flushing good oil for all those oil changes. Going forward i am going to do oil changes every 7k miles using mobile 1 5w-30 Extended Performance and mobile 1 M1-110A oil filter. Here is are the pictures of my oil at 6,630 miles using mobile 1 5w-20 synthetic and OEM oil filter. Let me what you think.
You'll most definitely be fine changing every 7K, especially using the Extended Performance. That oil is quite clean. Chemical properties (ability to effectively lubricate) is also important, but with Mobil 1 EP, that would certainly not be a problem at 3K miles.
My only suggestion would be to see if the M1-104A will fit the MDX. I can almost guarantee it will. That filter is used on the S2000 and is larger, essentially increasing the filtration surface area. It has the same threading as the M1-110A but the gasket is slightly larger. For the J35, it's still well within the oil filter connection so I'd think that would also be the case with the J37 you have in the MDX. I've used it on my 2006 and 2012 TL with good results.
How you drive has a lot to do with Oil Change interval frequency. Lots of short trips and city driving will contaminate oil much more quickly than fully warming up an engine by driving 15 / 20 miles after cold startup, therfore more frequent oil changes are beneficial. Also consider that my MDX (2013) has a fill capacity of only 4 1/2 quarts of engine oil. Lots of longer trips with a fully warmed up engine would allow 7,500 miles or so between changes while lots of 5 mile trips with intervals long enough to allow the engine to full cool off would require changes at 3,000 to 5,000 miles (or sooner). Also keep in mind that ONE YEAR is the maximum time any oil should be in your crankcase. Finally, Purolator makes a superior oil filter which you should consider to protect your engines service life.
Latent car nut
Not so my friend
The one year requirement applies to ALL oil types. The requirement is because no matter what the composition of the oil (mineral, vegetable, synthetic) it collects and retains contaminants created by the start up process that may contaminate, corrode, or otherwise damage your engine and its components. Please do not accept that synthetic oil removes the annual change requirement. Synthetic will provide lubrication properties after the one year period, but it carries the contaminants, acids, and other junk that the oil filter cannot remove back to the bearings, rings, etc. and WILL cause damage to the engine.
Latent car nut
