Help: Polarity of Radio Knob LEDs
Old Jul 11, 2017 | 11:22 PM
wusty23jd's Avatar
As the title states, I'm looking for insight regarding the polarity of the four SMD LED bulbs located around the VOL and TUNE knobs of the radio.
I"m in the process of completing the LED swap and haven't seen anyone who's specified the polarity of these. I already know/have documentation about the polarity of all other bulbs for the radio board. However, it seems that most people keep the knob LEDs unmodified. However, I want these to also match the other blue LEDs I've used in my car, so I will be swapping them out as well. In the below picture, I"m referring to the four square white LEDs outlined with red circles.
Any help would be awesome, especially from some of you guys, who've completed this modification in years past: dwb993 Esper.ice DeathMetal maddsiick NC916
Old Jul 12, 2017 | 01:12 AM
DogP's Avatar
I've never done the mod, nor even pulled that board... but have you tried using a multimeter to see if either side has continuity with either side of the ones that you do know the polarity of? It wouldn't be surprising if one side of the LED is GND, and one side of the bulbs is GND... in which case you'd see continuity with the multimeter, and know that it's the negative side of the SMD LED.
Pat
Old Jul 12, 2017 | 10:09 AM
wusty23jd's Avatar
That's a good suggestion. I'll have to try that after work.
Old Aug 5, 2017 | 12:10 PM
wusty23jd's Avatar
In case anyone is wondering, the polarity of the radio knobs is as follows:
