K23a1 Build
Old Jul 15, 2017 | 12:01 PM
  #1401
KenB350z's Avatar
Originally Posted by Haré romel
hi, kenB
I was thinking about putting 06 tsx cam, but put the bc stage2 turbo. Now I have vtec point very high, 7000rpm vs 06 tsx 6000rpm better for 7600rpm revlimit. I plan to go for 8000rpm but I risk because I'm stock down.
BC's are good, I just wanted to go with the best stock cam out there personally.
Old Jul 24, 2017 | 09:32 PM
  #1402
Haré romel's Avatar
Good, 06 tsx is excellent, I m planning go for 06 tsx too, for vtec point or check if my tuning was wrong way...
Old Jul 25, 2017 | 08:30 AM
  #1403
KenB350z's Avatar
Yeah, from what I've read those are about the same if not more aggressive than the type R cam.
Old Jul 25, 2017 | 08:34 PM
  #1404
Haré romel's Avatar
06 tsx More power than type r, big difference in no vtec lobe, little in vtec lobe.
Old Jul 28, 2017 | 11:43 PM
  #1405
KenB350z's Avatar
Slowly but surely!
Old Jul 30, 2017 | 10:24 PM
  #1406
KenB350z's Avatar
I got a little more done tonight. Crower valve looks hardly used. I will try to compare the three different cams tomorrow.
Old Jul 31, 2017 | 10:36 PM
  #1407
KenB350z's Avatar
Well, I got a little bit more done tonight. I'm so glad the RDX has a tall engine bay, it made pulling the head off quite easy. There is no need to remove the head studs. I have to say this K20a head looks pretty darn sexy on the k23a1 block! I hope to be done soon, but I did find some gaskets that needed to be replaced. I forgot this thing has over a 160k miles on it.
Old Aug 1, 2017 | 07:31 PM
  #1408
Haré romel's Avatar
Here we go, welcome, more picture about all work, good luck... :-)
Old Aug 4, 2017 | 10:52 AM
  #1409
bluecarbonfiber's Avatar
WTF?
Looks great!! makes me want to start over again.. im surprised you didn't add a brace for the floating deck.,. like this one http://i8.photobucket.com/albums/a50...y/IMG_1672.jpg
Old Aug 4, 2017 | 02:10 PM
  #1410
KenB350z's Avatar
I did some research on those, and read that they could do more harm than good. And a lot of K20 guys don't even run them, they just run the stock block. Apparently the K20 block is pretty Beefy from the factory, and I would assume the k23a1 block is stronger since it's boosted from the factory.
Old Aug 4, 2017 | 08:32 PM
  #1411
KenB350z's Avatar
I'm such a parts slut.....
Old Aug 11, 2017 | 12:39 AM
  #1412
KenB350z's Avatar
We finished a little more tonight! Oh yeah, the K20a cylinder head chambers are not as deep as the K23a. My new compression ratio will be some where in 9:1 range.
Old Aug 11, 2017 | 04:14 PM
  #1413
CrAzYNeSs's Avatar
Higher flowing head, slightest higher compression ratio, high revving.... I can't wait to see what comes next.
All these pictures are like car porn for us car fanatics. Lol
I noticed you guys left the engine while removing the timing chain. Surprised how much room there is to work with.
I'm so excited, cant wait to see. Keep us posted!
Old Aug 11, 2017 | 11:25 PM
  #1414
KenB350z's Avatar
My mechanic did say i should notice a difference in power out of boost, due to the increase in compression. I'll keep the pics coming!
Old Aug 11, 2017 | 11:42 PM
  #1415
KenB350z's Avatar
Ok, we got the valve adjustment done. The turbo manifold is tight and snug. Now just waiting on my radiator hose to get here. Tracking says it will be here tuesday. My mechanic did mention one thing, "after a 1000k miles or 1609.34 kilometers" we need to do another valve adjustment.
Old Aug 11, 2017 | 11:57 PM
  #1416
KenB350z's Avatar
Found a stopping point. Oh yeah, have to get some RSX spark plugs. The RDX ones do not fit.
Old Aug 12, 2017 | 05:06 PM
  #1417
KenB350z's Avatar
RSX on the left and RDX on the right. You can clearly see the RDX must have a deeper cylinder chamber to hold that long spark plug. I'm digging the girth of that RSX spark plug!
Old Aug 13, 2017 | 07:02 PM
  #1418
KenB350z's Avatar
Had to trim some of the RBC intake manifold in order to fit against the PRB water neck. I guess i didn't trim enough the first time. I should have a first start video soon!
Old Aug 13, 2017 | 11:22 PM
  #1419
KenB350z's Avatar
If it's too hot, go low low!
Old Aug 14, 2017 | 02:31 PM
  #1420
CrAzYNeSs's Avatar
Never thought I'd look at an engine and think "sexy". Thanks for the new pix!
Old Aug 14, 2017 | 06:56 PM
  #1421
Haré romel's Avatar
I used tsx head (or 06 si head) with side neck for this and used rsx spark too. all look beautiful, excellent work kenb. Waiting for first start.
Old Aug 14, 2017 | 07:00 PM
  #1422
Haré romel's Avatar
throttle body touch water neck?, or just replace some plugs?
Old Aug 18, 2017 | 11:37 AM
  #1423
KenB350z's Avatar
Thanks for the kind words! Should have it together soon!
Old Aug 18, 2017 | 11:41 AM
  #1424
KenB350z's Avatar
You know, when you have to cut off the water neck in order for it to fit a K20 head or RWC.
Old Aug 24, 2017 | 10:21 PM
  #1425
KenB350z's Avatar
Old Aug 25, 2017 | 02:07 PM
  #1426
CrAzYNeSs's Avatar
Sounds good! Congrats on getting everything up and running. I can't wait to see how everything turns out after a tune.
Old Aug 25, 2017 | 06:08 PM
  #1427
Haré romel's Avatar
Here we go :-), now serius tuned time, I ll like see reving now...:-) more picture...
Old Aug 26, 2017 | 02:24 AM
  #1428
KenB350z's Avatar
Old Aug 26, 2017 | 01:21 PM
  #1429
KenB350z's Avatar
The old MAF housing
The new MAF housing
Just sent Vit the new setup information for a retune. Let's see if he accepts it!
Old Aug 26, 2017 | 04:41 PM
  #1430
KenB350z's Avatar
Old Aug 27, 2017 | 12:01 AM
  #1431
TheWrench116's Avatar
FLETCH
Way to quiet...
Old Aug 29, 2017 | 03:30 PM
  #1432
Demon_S8's Avatar
Hey, Ken can you PM me when you get a sec, regarding upgrades. thanks
Old Aug 29, 2017 | 07:56 PM
  #1433
KenB350z's Avatar
It looks like you've exceeded the maximum messages you can receive, clear some of your old ones out.
Old Aug 29, 2017 | 09:09 PM
  #1434
exist12's Avatar
Did it take any customization to fit the K20 head or is it a direct swap? Do you have a parts list
Old Aug 30, 2017 | 07:23 AM
  #1435
Demon_S8's Avatar
RDX upgrades
Thanks, I just cleared the 1 message I had form administrator maximizing the inbox... guess it's newbie hazing, lol.
Old Aug 30, 2017 | 03:08 PM
  #1436
KenB350z's Avatar
It is a direct bolt-on.
The parts needed for the swap will depend greatly on your setup.
General parts:
K20 head
RWC head gasket
New OEM dowel pins
Head studs OEM or ARP (your choice)
I would not recommend running the factory turbo manifold. You will need to block off two water ports on the rear of the block, and if you did not intend on using the K20 head waterport you'll need the K tuned block off screw.
Old Aug 30, 2017 | 11:39 PM
  #1437
KenB350z's Avatar
Just waiting on my tune...
Old Sep 10, 2017 | 04:08 PM
  #1438
KenB350z's Avatar
Sent my first datalog, let's see what Vit can do with the new 4" MAF and K20/K23 frankenstein setup.
Old Sep 11, 2017 | 10:10 AM
  #1439
KenB350z's Avatar
On the second calibration with new setup, still light driving.
Old Sep 11, 2017 | 01:15 PM
  #1440
Haré romel's Avatar
My new tune it's like starting from zero.
wait video :-)
