Numairh's 3G TL Build Thread
Old Feb 9, 2017 | 01:21 PM
  #361
numairh's Avatar
UA6MT
Installed my Comptech short shifter last night. Love the way it feels!
Old Feb 9, 2017 | 03:00 PM
  #362
sockr1's Avatar
nice, i love my short shifter! you were luckier than me though, my gear shifter housing was welded to the frame so i had to do everything inside the car haha.
now you just need a heavy shift knob to complement it!
Old Feb 10, 2017 | 12:41 AM
  #363
numairh's Avatar
UA6MT
What, that is crazy! The hardest part for me was removing the bushing off the bottom of the original lever. That must have been even worse doing it in there! Also, it feels heavy with the OEM shifter, how would you compare the factory to a heavy one with the SS?
Old Feb 10, 2017 | 07:27 PM
  #364
Steven Bell's Avatar
I like that 2nd pic.
Old Feb 12, 2017 | 01:13 AM
  #365
Burtch07's Avatar
Looking sweet and love that new splitter
Old Feb 15, 2017 | 02:18 AM
  #366
numairh's Avatar
UA6MT
Old Feb 15, 2017 | 09:29 AM
  #367
sockr1's Avatar
yea it was horrible doing it inside the car!
the heavy shift knob makes the short shifter feel 100x better. i think i got rid of my oem knob in the first year i owned the car (back in 2008 haha). once you start getting into 6mt mods a heavy shift knob is almost a necessity. at a minimum you should get a 400g knob but i think if you're going to get a heavy knob, go for the best...raceseng! the weights are way higher (i have the slammer which is 635g) and their quality is the best i've ever seen...it will literally transform how it feels to drive stickshift.
have you also thought about getting hybrid racing shifter bushings? that will make the shifts crisper and more precise, it removes even more slop from the setup. easy switch out too, you just do it all in the engine bay (i did a short write up in my progress thread)
Old Feb 15, 2017 | 10:16 AM
  #368
BreezyTL's Avatar
HR bushings are a 15 minute job with a beer break! They remove the "sponge" feeling.
Old Feb 15, 2017 | 02:54 PM
  #369
numairh's Avatar
UA6MT
I think I will look into that soon. My issue is that I love the feel of a leather shift knob.. The bushings are on my list but right now my priority is to get my rear camber kits on because they've been sitting for 3 months already. And I need an alignment asap since I lowered the back a little bit.
Old Feb 15, 2017 | 03:04 PM
  #370
sockr1's Avatar
sounds like you have a plan! yea i don't think there are any heavy leather wrapped knobs so oem will do
Old Feb 20, 2017 | 02:38 AM
  #371
numairh's Avatar
UA6MT
Bye bye TE37 reps!
Old Feb 20, 2017 | 08:15 AM
  #372
Burtch07's Avatar
I love the new wheels way better!!
Old Feb 20, 2017 | 08:22 PM
  #373
numairh's Avatar
UA6MT
Another pic pic of the new wheels! They're Ambit RE02 18x9.5 +38 with a 20mm spacer all around (does not clear Brembos) wrapped in 225/40. The back rubs a bit so I will put the collar back into the rear coilovers and then finally install my camber kit this week so it stops rubbing! Taking suggestions for a new color! Thinking bronze or just silver again.
Old Feb 20, 2017 | 08:23 PM
  #374
^^^ Dude, looks great....perfect stance too.
Old Feb 21, 2017 | 12:57 PM
  #375
MyGuti's Avatar
those wheels look pretty amazing!!! Thanks for posting the specs, might have to order those. Which color do you have the wheels in? Gunmetal?
Old Feb 21, 2017 | 01:09 PM
  #376
rockstar143's Avatar
Super nice, Num...
love it.
Old Feb 21, 2017 | 11:22 PM
  #377
numairh's Avatar
UA6MT
Put the collar back in the rear coilovers. No rubbing but I don't like the rake... I might raise the front a quarter inch.
Old Feb 22, 2017 | 07:23 AM
  #378
Those are a knock off of the enkei I wanted...but in specs that aren't overly aggressive...love it.
Old Feb 22, 2017 | 09:29 AM
  #379
numairh's Avatar
UA6MT
They are a bit on the aggressive side, when I had the rear collar removed they would rub constantly but very slightly, now it doesn't rub at all.
Old Feb 22, 2017 | 09:42 AM
  #380
sockr1's Avatar
the specs aren't aggressive but your spacers are hahah! go down to 15mm spacers from the 20mm and you'll be fine to go as low as you want.
Old Feb 22, 2017 | 11:44 AM
  #381
numairh's Avatar
UA6MT
Yeah I meant with the spacers it's a bit aggressive, but I can't go down to 15. With the 20mm in the front, I can't even fit my car key between the brake and the spoke.
Old Feb 22, 2017 | 12:07 PM
  #382
sockr1's Avatar
^^ crazy haha!!
just buy the right wheel specs lol!! I kid I kid (I'm just a spacer hater), new setup looks great! I think a brighter color would look great like hyper silver or gunmetal
Old Feb 22, 2017 | 01:19 PM
  #383
numairh's Avatar
UA6MT
^^ crazy haha!!
I had spacers for over a year with no issues, so I just buy specs that will work with a 20mm spacer to clear the brakes because there are so many wheels I like which don't fit without them. I'm painting them soon when I have time.
Old Feb 23, 2017 | 12:24 AM
  #384
numairh's Avatar
UA6MT
I've been busy with this car... I raised the front of the car about .25 inch to even the rake out. I also wrapped the front and rear trim in matte silver for the factory look. The pieces are sanded down underneath for the fake chrome look. Sanded that last year and it was the biggest mistake.
Old Feb 24, 2017 | 03:45 PM
  #385
07WDPUA7's Avatar
Highly recommend that you get a weighted and countersunk shift knob. Makes shifting way better compared to the stock shift knob. This is the one that I have from HeelToe.
https://www.heeltoeauto.com/maven-co...on-10x1.5.html
Old Feb 24, 2017 | 11:43 PM
  #386
numairh's Avatar
UA6MT
Finally got around to installing my camber kit by SPC. So I was under the impression that you can add 2 degrees negative and 4 degrees positive camber but I guess it was the other way around. I was expecting to be at -5 maxed out with he arms but I ended up with like -7-8. I backed it back out to about -4 degrees. SPC arms maxed out.
Backed out to about -4. Alignment coming next week.
Old Feb 27, 2017 | 07:08 PM
  #387
Wow, that is some serious tuckage.
Old Feb 28, 2017 | 07:40 PM
  #388
nip tuck, baby.
Old Feb 28, 2017 | 08:03 PM
  #389
Back for another look!
Old Mar 4, 2017 | 06:37 PM
  #390
numairh's Avatar
UA6MT
Got it aligned finally and they didnt even need to touch the camber because I had eyeballed it so close that it wouldn't make a difference changing it. It's -5.1 passenger and -5.4 driver. Also got the rear tires flipped. I have quads sitting in my room waiting to get welded on, oem type s taillights being installed this week and then going to paint my wheels!
Old Mar 4, 2017 | 08:06 PM
  #391
sockr1's Avatar
Looking good man! What color wheels? Also if you're getting new or like new headlights put on, have a shop put on a clear wrap so they don't haze or get damaged (usually about 80-100 bucks with a 5-7 year warranty)
Old Mar 4, 2017 | 08:47 PM
  #392
numairh's Avatar
UA6MT
Thank you! And I'm thinking about gloss silver because I don't want anything crazy. I actually put Laminx film on them a couple months ago and they look great!
Old Mar 4, 2017 | 09:05 PM
  #393
Burtch07's Avatar
Looking very very sexy!! With a silver car I think almost every color would look good.
Old Mar 5, 2017 | 03:45 AM
  #394
treal512's Avatar
Nice build. Noob question, but what are you side markers? Depot?
Old Mar 5, 2017 | 06:21 PM
  #395
Burtch07's Avatar
He has the Type-S depo side markers. The parking lights on the side in the rear
Old Mar 5, 2017 | 10:28 PM
  #396
numairh's Avatar
UA6MT
I'm actually thinking about doing silver with a sparkle clear coat... (Duplicolor clear effex, but not super heavy, just so you can see a little rainbow sparkle in the sunlight)
Yes they are the Type-S smoked Depo. You can get them off eBay or Unique Style Racing.
Old Mar 5, 2017 | 11:31 PM
  #397
treal512's Avatar
Thanks, man. Did you go with just the rears or the full 4-piece set? I'm wondering if the Depos will match my front OEM markers.
Old Mar 6, 2017 | 01:00 AM
  #398
numairh's Avatar
UA6MT
I got the full set because I wanted the white LED fronts. They will not match the OEM because they are gray while Depo is black.
Old Mar 6, 2017 | 07:01 PM
  #399
Love it....great look!
Old Mar 10, 2017 | 10:12 PM
  #400
numairh's Avatar
UA6MT
Installing OEM Type S taillights
