Oh Sickest TL's '06 Royal Blue Pearl
Old 08-22-2016, 07:04 AM
  #1561
rockstar143's Avatar
Received 19,996 Likes on 14,504 Posts
On both sets of my headlights I found that the ability to put spacers in was very limited...I did 1 spacer and it worked, but then when I tried 2 I broke the retaining clip because it was too tight!
Old 08-22-2016, 02:17 PM
  #1562
Jeff
Oh Sickest TL's Avatar
when you say the bulb is not "seated" properly... how exactly should it be seated? lol and can I reach the drivers side bulb by taking the battery out or through the wheel well ? Im not taking the bumper off lol
Old 08-23-2016, 07:28 AM
  #1563
Wheel well...remove wheel, move liner out of the way and you can get at it.
There's no way that's your problem...there's only one way to put the bulb in with the 3 ridges and the 2 clips. There's no way you messed it up.
Ones just sharper than the other...
put it up against a wall at night with complete darkness and align the left and right step cutoffs to each other.
Old 08-23-2016, 08:26 AM
  #1564
Received 8,712 Likes on 6,719 Posts
We need pics to see what we're working with..
Old 08-23-2016, 09:03 AM
  #1565
Jeff
I know I know.. I just dont have 25ft, a flat surface and a wall in the same spot lol. ill try and get something tonight for y'all to see.
And like J said I doubt its the bulb not being put in correctly, theres only one way for it to go so I doubt I fucked that up .
Old 08-23-2016, 09:07 AM
  #1566
Originally Posted by Oh Sickest TL
I
You're giving yourself too much credit
It's all speculAtive now anyway.
But while you're at it, check the blinker fluid and flux Capacitor coolant level, not the flux capacitor itself. People always think it's the damn flux capacitor and never bother to check the coolant level
Old 08-23-2016, 09:09 AM
  #1567
Jeff
Brb
Old 08-23-2016, 10:57 AM
  #1568
THE BACK OF A WALMART USUALLY HAS WHAT YOU NEED...
and also a flat 25 ft section with a light colored wall
Old 08-23-2016, 11:49 AM
  #1569
UlsterBoy13's Avatar
I agree...pics of new headlights with bulbs to make sure they look suitable.....
Oh Sickest TL (08-23-2016)
Old 08-23-2016, 12:32 PM
  #1570
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
are you guys still talking about his car? or....
The following 3 users liked this post by cu2wagon:
EvilVirus (08-23-2016), Oh Sickest TL (08-23-2016), thoiboi (08-23-2016)
Old 08-23-2016, 01:16 PM
  #1571
Jeff
this is what we are working with here. you can see that there are two steps and they dont align vertical or horizontally?? also a huge hot spot in the beam pattern on the bottom on the drivers side. wtf is going on. car is accident free and it didnt start doing this until I lowered it and customized the headlights lol
Old 08-23-2016, 01:18 PM
  #1572
Looks like passenger side needs to come up...left one should lead into the right upper one.
Old 08-23-2016, 01:28 PM
  #1573
Jeff
yea? what about that empty void in the ground though?
  #1574
cu2wagon's Avatar
Yeah, left is higher than right. Not sure which is correct, but there is probably a manual, or something, for owners to look up the proper height.
I'd suspect the hot-spot is just from both beams overlapping incorrectly at that particular location. Get them adjusted up/down correctly and see what the output looks like.
The following 2 users liked this post by cu2wagon:
Oh Sickest TL (08-23-2016), rockstar143 (08-23-2016)
Old 08-23-2016, 01:29 PM
  #1575
Jeff
makes sense. I'm on it
Old 08-23-2016, 01:33 PM
  #1576
Driver's side bulb looks proper but my money is still on the passenger side bulb having some debris or something and it not in the projector properly. I'm trying to do a google search of an old post TheRetrofitSource posted about different hotspots and bulb seating.. hang tight.
ALso the driver's side looks very high in my humble opinion
what kind of bulbs are those jefford?
Old 08-23-2016, 01:37 PM
  #1577
Jeff
6500k morimoto xb35.
the headlights look clean,theyre brand new and mint so I dunno
Old 08-23-2016, 01:43 PM
  #1578
sockr1's Avatar
Received 1,159 Likes on 909 Posts
raise the right side of your car 6 inches to even out the headlights
good luck jeff that seems frustrating!
  #1579
Jeff
Old 08-23-2016, 01:45 PM
  #1580
I think there may be a protrusion on the bulb or on the mating surface on the back of the headlightl such that the bulb isn't fully flush with the projector. Either that or the spring isn't providing even pressure all around.. Sometimes definitely funky. Or it could also be the bulb is crooked itself, not unheard of and TRS will definitely replace it.
  #1581
this may or may not help.....
How to Adjust Your Headlights - Aim Your Headlights
Many models (particularly Hondas and Acuras) have a bubble level in the headlamp assembly to check vertical aim. This does make it easier to diagnose unwanted tilt. Just make sure the tire pressures are at specs and the vehicle is on level ground (check with a carpenter's bubble level on a flat surface). Have the fuel tank half-full and someone in the driver's seat. Reposition the car if necessary to get a level location. Jounce each side of the front end of the car up and down a few times to settle the suspension. Measure from any convenient fixed point on each of the headlamps to the ground; the measurements should be within 1/2 in., indicating the suspension is not sagging excessively at either side. Then, locate the vertical adjuster and turn it to center the bubble.
Even if your headlamps have a bubble level, it's strictly for vertical aim. It's less common, but still possible, for the headlamp aim to be off horizontally. The left headlamp may be aimed at the oncoming cars instead of straight ahead or slightly to the right, and that's equally annoying. But you might be in luck. Some cars with a bubble level for vertical aim also have an alignment indicator for horizontal aim (here again, Honda and Acura). You just have to turn the adjuster to reset the indicator.
Old 08-23-2016, 01:51 PM
  #1582
cu2wagon's Avatar
Is it too soon to recommend spraying the headlights with plastidip?
Old 08-23-2016, 01:56 PM
  #1583
Jeff
so they need adjusted/aligned for sure.
but jawknee you have me concerned. Why do you think something is wrong with the passenger side? Its very possible that the bulb could have been damaged or some debris on it
Old 08-23-2016, 02:17 PM
  #1584
It looks very indicative of a bulb issue, I do headlight retrofits on the side so I've seen my fair share of issues.
Old 08-23-2016, 02:18 PM
  #1585
Jeff
so what would you advise to do ? inspect bulb for ? or just get new bulbs lol
Old 08-23-2016, 02:20 PM
  #1586
cu2wagon's Avatar
Get the beams adjusted correctly.
Swap bulbs left to right and see if the problem follows the bulb or stays with the housing.
  #1587
inspect bulb, inspect projector, flip bulbs to other side to see if that alleviates the issue or to definitively see if it is the bulb, then reach out to TRS for warranty if so.
They're not bad bulbs, I use them in all my retrofits, but there's always room for error; nothing's perfect.
Old 08-23-2016, 02:21 PM
  #1588
cu2wagon's Avatar
I thought you were an Engineer? That's just basic scientific method.
Shame.
EDIT: Also, BROTHER!
Old 08-23-2016, 02:23 PM
  #1589
Jeff
ffs I really dont want to do this lol
and what am I looking for. I still dont know what exactly you see in that picture that illustrates the pass bulb is perhaps damaged
Old 08-23-2016, 02:24 PM
  #1590
Shame.
skip the plastidip, just part out the POS car altogether...
The left output against the wall looks optimal,
the right output has a substantial 'hot spot'. no bueno
Last edited by Steven Bell; 08-24-2016 at 08:25 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand side of each post.
Old 08-23-2016, 02:26 PM
  #1591
Jeff
where? I see a void in the bottom drivers side portion but not sure where you mean
Old 08-23-2016, 02:28 PM
  #1592
So you have two problems:
1. you need to lower your driver's side such that your cutoff line up like so:
2. adjust your passenger's side bulb to get rid of that awful hotspot.
Old 08-23-2016, 02:31 PM
  #1593
Jeff
hmmmm ok that is weird...ill get a diff pic cuz that just may be the pic quality and lighting and such.
Thanks Jawknee
Old 08-23-2016, 02:33 PM
  #1594
lotta spoonfeeding in here...
noprob bud
Old 08-23-2016, 02:37 PM
  #1595
Jeff
Old 08-24-2016, 09:27 AM
  #1596
sockr1's Avatar
i've always wondered why the cutoff should be like that...is that so you don't blind other drivers and it's lower? just my own curiosity i don't know much about headlights, bulbs, lenses, all that crap, which is why i never upgrade my headlights haha
Old 08-24-2016, 09:33 AM
  #1597
cu2wagon's Avatar
Basically. It throws as much light ahead of you as possible. The lower cut on the left is so you don't blind oncoming traffic while the higher bit on the right illuminates the side of the road and signage.
The cutoff profiles are swapped for LHD countries.
sockr1 (08-24-2016)
Old 08-24-2016, 09:40 AM
  #1598
Jeff
yea drivers side is suppose to b a little lower to not blind oncoming traffic...
this is what I'm working with now.. i think both bulbs may be a little high in general so ill put both down accordingly
still a slight hotspot in the passenger area, maybe ill grab some osram CBIs or something. what do you guys recommend. I want pure white with a little bit of blue
Old 08-24-2016, 09:53 AM
  #1599
they're even...it's two s's if you really look at how they both shoot.
Looks pretty good.
Oh Sickest TL (08-24-2016)
Old 08-24-2016, 10:06 AM
  #1600
Looks much better from height perspective, just check the bulb. They're decent bulbs and after burn-in (40-50 hours typically) it should look better as well.
Quick Reply: Oh Sickest TL's '06 Royal Blue Pearl
