Whistle/chirp from heater
Old Oct 29, 2013 | 05:56 PM
SilverMike's Avatar
Hi guys,
When it's really cold out and I have the heater on, I get a subtle whistle or chirp sound from the fan or some other component. I've brought it up with the dealer, but of course it doesn't happen when the car's in. Any ideas? They didn't see any leaves/blockages.
Old Oct 30, 2013 | 06:36 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Same problem here. A quick search using google and the right keywords and found a few posts in all kinds of forums saying that its dry or worn bushing in the blower motor and needs to be replaced. Usually it lasts a long time, even with the noise, before it stops working all together. I'll wait and see what happens. Replacing that piece is pretty easy if you feel confident enough to start taking things apart under the passenger side dash. You need to remove the filter from inside the globe box, and the panel underneath the dash that is hanging there with clips. Then its 3 bolts to remove the heater fan. The part at online parts stores (79310-TK4-A41) sells for around $55-$70.
Old Nov 7, 2013 | 07:09 PM
Tonyware's Avatar
... I looked at the process of removing this and it is a bit more complex than what I described. Needless to say unless you have the shop manual don't attempt. Apparently it also involves cutting off some plastic tabs. Not sure even if I would attempt this myself some day.
Old Nov 7, 2013 | 07:23 PM
dwest1023's Avatar
I had a noise from my fan at low speeds when cold, with my 09. I got hold of the fan blade and wiggled it a bit and pulled up and down.Noise has not returned since. That was last winter.
Biggie_B
May 27, 2025 05:51 PM
rp_guy
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
summit21
Sep 20, 2015 09:47 AM
