DLC pin on the 09 tsx manual obd2 port
Old 04-25-2014, 10:41 PM
5th Gear
indodarknight's Avatar
Question DLC pin on the 09 tsx manual obd2 port
Does anyone has a picture of the DLC pin on the 09 tsx manual obd2 port?
I've search everywhere online, and I can't seem to find it,
I need it to help me figure out on the difference between the 09 tsx and 11 accord, so I can use flashpro on my accord,
thanks,
Old 04-26-2014, 09:36 AM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
What is DLC pin?
Is that the orientation of the pins in the OBD II? I'm not really sure I understand what you're asking. OBD II is the same across all platforms if that's what you're asking.
If you're asking if the ECU is different, the answer is yes. I do believe someone flashed an 11 accord with 09 TSX calibration but lost a lot of internal functions.
Old 04-26-2014, 11:32 AM
UTAH TSX's Avatar
thanks,
I gave that to you a while ago on my 8th accord, I can post it here on monday if I'm not to busy at work, the big difference is the communication line and what pin on the ECU it goes to I think the DLC connector is the same
Good luck
let's help this guy get his accord boosting it's been on his car for several years but he cannot boost or it goes into limp mode
Old 04-26-2014, 02:51 PM
5th Gear
Originally Posted by ssjoeboe9
What is DLC pin?
i think that guy you're talking about is me, but i haven't been able to upload my calibration to my 09 tsx ecu, it keeps on telling me the wen error, so i was thinking, maybe the accord and tsx obd2 port might be slightly different, just like how the 04 has flashpro and the 07-08 has to repin some of the pin on the port so the flashpro will work
Good luck
yeah, thanks, I tried going to m8g for the past like 5 months, and no luck
its been down, like forever... hahahaha
Old 04-26-2014, 02:56 PM
5th Gear
here is what my pin out, its says that my red on 12 is my wen pin, but i've check and double checked on my wiring, and nothing is out of place, so I'm thinking the 09 tsx ones has 1 or 2 pins that could be in a different location than the accord one
Old 04-26-2014, 03:50 PM
UTAH TSX's Avatar
Here is an automatic 2009 can anyone take pictures of a manual 2009-2010 DLC connector
Attached Thumbnails DLC pin on the 09 tsx manual obd2 port-20140426_141449.jpg   DLC pin on the 09 tsx manual obd2 port-20140426_141757.jpg
indodarknight (04-27-2014)
Old 04-27-2014, 04:00 AM
optimusaccord's Avatar
Where is it located? I might be able to as soon as I get my car back....
Old 04-27-2014, 08:45 PM
5th Gear
whoa, this whole time i thought you were 6spd? thanks a lot, that pix was a big help
cycdaniel
12-17-2019 10:58 AM
Puma Jim
20
10-20-2016 11:59 AM
mugen_kid
11-13-2015 10:38 PM
09-17-2015 09:01 PM
ivegotthenav
09-11-2015 07:51 PM
Quick Reply: DLC pin on the 09 tsx manual obd2 port
