Cannot access menu after battery change
Old 06-30-2017, 08:16 PM
Jimbozeubuen's Avatar
Hi,
I have a 2012 Acura TSX. After a battery change, the clock and radio are no longer working. I tried to access the menu, but nothing shows up on the screen. Any suggestions?
Thanks,
Jimmy
Old 07-01-2017, 06:55 AM
TSXV6Guy's Avatar
Disconnect the newly installed battery, then connect the car's Positive and Negative cables together for about 1 minute. Then re-connect the car's Positive wire to the battery and tighten the connection properly. Last, connect the Negative wire to the battery.
When connecting the negative cable to the battery, ensure it is being connected firmly - just a single movement without hesitation etc.
See if this helps. Then you'll need the code for the radio. If you don't have it, look in the fuse box for a sticker.
swimgeek44
3G TL Photograph Gallery
27
08-12-2017 11:40 AM
zoomchey1
1/2G MDX (2001-2013)
06-24-2017 10:43 PM
Gadgetjq
2G RDX DIY & FAQ
06-11-2017 08:50 AM
HDVidTech
06-11-2017 08:23 AM
Carman3
05-30-2017 11:33 AM
Quick Reply: Cannot access menu after battery change
