Cannot access menu after battery change
Hi,
I have a 2012 Acura TSX. After a battery change, the clock and radio are no longer working. I tried to access the menu, but nothing shows up on the screen. Any suggestions?
Thanks,
Jimmy
Thanks,
Jimmy
Disconnect the newly installed battery, then connect the car's Positive and Negative cables together for about 1 minute. Then re-connect the car's Positive wire to the battery and tighten the connection properly. Last, connect the Negative wire to the battery.
When connecting the negative cable to the battery, ensure it is being connected firmly - just a single movement without hesitation etc.
See if this helps. Then you'll need the code for the radio. If you don't have it, look in the fuse box for a sticker.
HDVidTech
06-11-2017 08:23 AM
