Programming a 2002 TL-S Key
Smurfette
Hello all! I recently purchased an 02 TL-S a few weeks ago, and absolutely love it!! I bought a key from Ebay, and was wondering if I have to go to the dealer in order to program the key. Please help! Thank you!!
1...your new key
2...a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait. the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light is off, car should start.
For the remote part. in drivers seat WITH DOOR OPEN. start with door unlocked. first put master key in ignition, turn to on, then back off and remove. using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
Close drivers door, open drivers door.
Performe lock/unlock procedure again.
insert key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
Now press both lock and unlock buttons on REMOTE. release after about 1.5seconds. now press just the lock button on remote.
now open and close the drivers door a couple times to close programming. if you did it right, remote will now work.
The following 7 users liked this post by fsttyms1:
3.2TLc (10-24-2012),
Arkady (11-06-2017),
hamburglar490 (04-02-2013),
RMoody18 (09-24-2014),
TheSeanR (04-22-2013),
and 2 others liked this post.
1...your new key
Thanks.
'12 & '13 AL West Champs!
Hmmm, I hope so. I was looking at a key/fob online here:
http://cgi.ebay.ca/1999-2000-2001-99...ayphotohosting
And that seemed to indicate in the description that I have to get it programmed by a locksmith. I guess I can always get my key cut, try these steps, then run back in and cough up the cash if it doesnt work.
Also, do you know whether it's important for the fobs that I replace the one I've lost, as in the #1 and #2. I keep hearing about that, but I really dont know since none of these sites selling them indicate which number their fobs are.
1...your new key
When you say to press the gas pedal once to the floor I am assuming you also mean to release it. Is that correct? Or do I keep the pedal to the floor until the security light goes off?
Thanks for your help!
2006 NBP TL MT6/ 02TL-S
Bump...any more info on this? This didn't work for me either.
I have an 02 TLS, have the second remote programed OK, got the second key cut and it turns the locks, but no luck after muliple tries to program the key by this method.
Yes or No-does this work on a 02TLS???
I have tried this again & again and cannot get car to enter programing mode.
I have waited for a full moon, stood on one leg, faced north, chantted weird stuff and farted while trying this procedure-no luck
Can anyone confrim they got this to work on a 02TLS...??
The following 2 users liked this post by eastoftheleast2013:
3.2TLc (04-07-2013),
Mr_Cargasm (04-13-2013)
Yeah I Just did mine today got it cut and programmed for $30 dollars at lowes. Thats your best bet IMO saves the trouble
From the above I'm not sure how to program new keys to my 2003 tl. I have both original keys but from bad experience with ford (cost $170) when I misplaced my 2nd key I would like to have a backup. Bob
Hate to ask..
1...your new key
Latent car nut
Received 2,005 Likes
Yes.
io really hate to bring this thread back up but i need to clarify 2 quick points i am not seeing , tho forgive me as i am an oldie-- though i will argue also a goodie--anyway---- programming a new key--- you do mean to hold the accelraqtor down and release for the new key ? or hold it down and no relaese ?--- secondly-- when i program a key-- will i have to then reprogram the original key as i did the fob?
MetalGearTypeS
08-29-2016 08:28 PM
soupi
14
11-15-2015 11:15 AM
02, 2000, 2002, acura, cl, fob, forum, key, program, programing, programming, remote, security, tl, transponder
