Programming a 2002 TL-S Key
Old Aug 9, 2006 | 10:43 AM
Taheya's Avatar
Smurfette
Cool Programming a 2002 TL-S Key
Hello all! I recently purchased an 02 TL-S a few weeks ago, and absolutely love it!! I bought a key from Ebay, and was wondering if I have to go to the dealer in order to program the key. Please help! Thank you!!
Old Aug 9, 2006 | 11:17 AM
fsttyms1's Avatar
1...your new key
2...a MASTER KEY (one with the remote in it)already programmed to car.
to program the transponder- (thats the immobilizer part)
sitting in dr. seat, put the master key in ignition, and turn to on.engine OFF. press the gas pedal 5 times to floor and release. now press brake 6 times (press and release)
remove master key from ignition. install new key and turn to on...engine off. press gas to floor once. now wait. the security light will blink for about 45-60 seconds, then it will go off if you did it correctly. once the light is off, car should start.
For the remote part. in drivers seat WITH DOOR OPEN. start with door unlocked. first put master key in ignition, turn to on, then back off and remove. using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
Close drivers door, open drivers door.
Performe lock/unlock procedure again.
insert key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
Now press both lock and unlock buttons on REMOTE. release after about 1.5seconds. now press just the lock button on remote.
now open and close the drivers door a couple times to close programming. if you did it right, remote will now work.
Old Aug 9, 2006 | 12:19 PM
Taheya's Avatar
Smurfette
Thank you so much! I will try this when I get home from work. I will let you know if it works!!
Old Aug 9, 2006 | 12:51 PM
fsttyms1's Avatar
Old Mar 23, 2009 | 07:22 PM
bcred's Avatar
3rd Gear
Originally Posted by fsttyms1
1...your new key
Hi, sorry to bump an old thread, but will this also work for a 2000 TL? I keep hearing mixed messages on it and even my dealer didn't seem to be entirely sure.
Thanks.
Old Mar 23, 2009 | 07:27 PM
Gfaze's Avatar
S E L L
Thanks.
It should be the same.
Old Mar 23, 2009 | 08:57 PM
bcred's Avatar
3rd Gear
Hmmm, I hope so. I was looking at a key/fob online here:
http://cgi.ebay.ca/1999-2000-2001-99...ayphotohosting
And that seemed to indicate in the description that I have to get it programmed by a locksmith. I guess I can always get my key cut, try these steps, then run back in and cough up the cash if it doesnt work.
Also, do you know whether it's important for the fobs that I replace the one I've lost, as in the #1 and #2. I keep hearing about that, but I really dont know since none of these sites selling them indicate which number their fobs are.
Old Oct 22, 2012 | 05:10 PM
codj2k's Avatar
5th Gear
Hi, sorry to bump an old thread.
I tried this on a 2003 TL without success. Are the instructions different?
Old Oct 22, 2012 | 06:59 PM
jra8858's Avatar
Would this work on a 2000 tl-p?
Old Oct 23, 2012 | 04:16 AM
Karanx7's Avatar
Unregistered Member
O sweet, never knew about this. Will this overwrite any old keys/remotes?
Old Oct 23, 2012 | 06:04 AM
deeplies's Avatar
1...your new key
just amazing, how can you find this out?
Old Oct 23, 2012 | 09:54 AM
fsttyms1's Avatar
This was taken from the CL side many many years ago.
Old Oct 23, 2012 | 10:53 AM
MilwaukeeDave's Avatar
Is there a switchblade key that can be programmed for our TL? I see newer TLs have them, is there a year we could use? Or an aftermarket? Doing a search really just brings up keys for sale.
Old Dec 12, 2012 | 11:33 AM
Dave Bowering's Avatar
When you say to press the gas pedal once to the floor I am assuming you also mean to release it. Is that correct? Or do I keep the pedal to the floor until the security light goes off?
Thanks for your help!
Old Dec 12, 2012 | 02:17 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
You still have to get the new key cut first, right?
Old Dec 12, 2012 | 02:27 PM
Es617's Avatar
I assume so i would rather have a blank key programmed for my auto start tho
Old Dec 14, 2012 | 08:48 AM
AlanW's Avatar
Bump...any more info on this? This didn't work for me either.
I have an 02 TLS, have the second remote programed OK, got the second key cut and it turns the locks, but no luck after muliple tries to program the key by this method.
Old Mar 29, 2013 | 02:46 PM
OhRDX's Avatar
Bump for great thread.
Bought two keys on fleabag for $14. Lowes cut them for me for free. Programmed flawlessly.
No more worries about losing/breaking only key!
Old Apr 2, 2013 | 03:35 PM
AlanW's Avatar
Yes or No-does this work on a 02TLS???
I have tried this again & again and cannot get car to enter programing mode.
I have waited for a full moon, stood on one leg, faced north, chantted weird stuff and farted while trying this procedure-no luck
Can anyone confrim they got this to work on a 02TLS...??
Old Apr 6, 2013 | 08:26 PM
eastoftheleast2013's Avatar
4th Gear
I went to lowes today and got an ignition key cut AND programmed for $29. Why would anyone go through this when you can just go to lowes and have them do it for that price?
Good luck.
Old Apr 6, 2013 | 08:27 PM
4th Gear
Mine is a 2003 Acura TL Type-S. I believe they can program up to 2003, but beyond that it's a no go.
Also, ACE hardware can do it, but Home Depot Cannot
Old Apr 13, 2013 | 10:39 PM
Mr_Cargasm's Avatar
6th Gear
Yeah I Just did mine today got it cut and programmed for $30 dollars at lowes. Thats your best bet IMO saves the trouble
Old Apr 18, 2013 | 02:24 AM
acura_dipset_tl's Avatar
AM To WDP In My Garage
The Lowe's in my area won't cut and program my key, they said I have to buy there's. There key sucks it's just a plain key without the Acura logo on it. The key is for a 2g cl which is basically the same thing as the 2g tl.
Old Sep 24, 2014 | 09:34 PM
RMoody18's Avatar
wait a minute! lowes will program them?
Old May 3, 2015 | 12:20 AM
seagull10's Avatar
From the above I'm not sure how to program new keys to my 2003 tl. I have both original keys but from bad experience with ford (cost $170) when I misplaced my 2nd key I would like to have a backup. Bob
Old Nov 5, 2017 | 02:54 AM
MonadoLink's Avatar
Does this same method work with a base 02 TL? The remote instruction s seem to differ
Old Jan 22, 2019 | 07:55 PM
Renee Peters's Avatar
Hate to ask..
1...your new key
I have a 2003 Acura TL Type S, will this work for my car??
Old Jan 23, 2019 | 03:57 AM
horseshoez's Avatar
Latent car nut
Yes.
Old Oct 14, 2020 | 07:13 PM
superpap56's Avatar
io really hate to bring this thread back up but i need to clarify 2 quick points i am not seeing , tho forgive me as i am an oldie-- though i will argue also a goodie--anyway---- programming a new key--- you do mean to hold the accelraqtor down and release for the new key ? or hold it down and no relaese ?--- secondly-- when i program a key-- will i have to then reprogram the original key as i did the fob?
MetalGearTypeS
Aug 29, 2016 08:28 PM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
