need help reading engine codes
Old 08-07-2005, 10:46 PM
www.grounded4life.org
mikey3.2's Avatar
i have a 99 tl with 72000 miles on it n yesterday i was out front of my friends house waiting for him to come out n out of nowhere my car started to vibrate n my check engine n tcs lights come on. it only seems to do it when im stopped n then when i start off the car starts to putt or i guess misfire. i went to all the auto part stores around my house to get a helmms manual n they dont have any can someone tell me how i can read the codes my self . thanx
Old 08-07-2005, 10:48 PM
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
Take it to autozone and have them scanned free.
Old 08-08-2005, 08:49 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
take it back to the parts store and let them read teh codes. thats the only way.
and you cant buy a helms manual in stores. you have to order it from helms
Old 08-08-2005, 01:40 PM
ncxvtguy83's Avatar
the same thing happen to my car last night. I was driving and all of a sudden the check engine light started blinking. Then finally it stayed lit with my tcs light also lit. The car is sputtering and is not responsive. The idle is low and the car sputters at idle as if it wants to shut off. When I accelerate it doesn't want to go.
I took it to autozone and they pulled misfire codes for cylinder 1,2,3,4. Another code for random misfires and lastly it says a code for ignition system & "or misfire" in parenthesis. I changed the spark plugs and they are still throwing the same codes. Last guesses are the coil packs, but all 6? I took it to a shop today, he said it might be the fuel pump. Can misfires occur due to several reasons? meanwhile, I'm still searching old posts.
Old 08-08-2005, 05:42 PM
03CoupeV6's Avatar
Weren't TL's under ignition recalls? Could that be the reason?
BTW - a blinking CEL indicates that continuing to drive could do irreversible damage. You should stop immediately if the CEL blinks.
Old 08-08-2005, 05:50 PM
ncxvtguy83's Avatar
i believe that was the key ignition recall. The code that I read today said ignition system. Well, I hope I didn't do too much damage. It's going to be parked now until I can figure this out. Thanks for the heads up.
Old 08-09-2005, 08:31 PM
mikey3.2's Avatar
just borrowed my friends code reader n here r the codes i got 0300 0301 0302 0303 0304 0305 0306 1399 n 1676 can someone who has the code list let me know what these r thanx
Old 08-09-2005, 10:07 PM
ncxvtguy83's Avatar
P0300/P1399 -Random Misfire
P0301- No. 1 Cylinder Misfire
P0302- No. 2 Cylinder Misfire
P0303- No. 3 Cylinder Misfire
P0304- No. 4 Cylinder Misfire
P0305- No. 5 Cylinder Misfire
P0306- No. 6 Cylinder Misfire
P1676- FPTDR Signal Line Malfunction ( I believe it's related with your PCM/ABS/TCS wires or control system units.)
Do whatever you like with this info, as I am just giving you what the code means. Goodluck and don't mention it!
Old 08-09-2005, 10:10 PM
ncxvtguy83's Avatar
Ok, I brought it to the acura dealer/stealer.... Charged me damm 180 bucks for spark plugs and a diagnosis. They told me my timing belt is out of timing.
I had just got a timing belt service done else where. So I brought it back to the mechanic that did the timing belt service for me. They take the covers off and find that the timing is all in place. We also did a compression test on all the cylinders with 180psi evenly among all 6 cylinders. Appears to me they did not know what the hell they were doing. They didn't even check my fuel pressure.
Old 08-10-2005, 07:15 PM
mikey3.2's Avatar
does anybody else know anything about this p1676 code n what else i can do besides change the plugs that could stop it from misfiring. dont want to take it to the dealer n pat out my ass. thanx
Old 03-26-2008, 09:31 PM
5th Gear
jgallagher392's Avatar
hey mikey did you ever figure out what was wrong with your 1676 code? how did youy fix it? I just purchased a 1999 Acura TL 3.2 and it is missing, had a friend hook it up to a diagnostic comp and the code P1676 TCSDL (FPTDR) Signal failure came back. PLEASE HELP! any info about your experience would be greatly appreciated. I don't want to spend an arm and a leg trying to find a problem if I can figure it out and then take it in to be fixed it would save me quite a bit of time. The biggest problem is I cannot stop driving it until I figure this out.
again any help at all would be greatly appreciated
Jen
mada51589
05-03-2022 08:54 PM
01CLOwner
10-09-2015 01:07 PM
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: need help reading engine codes
