need help reading engine codes
i have a 99 tl with 72000 miles on it n yesterday i was out front of my friends house waiting for him to come out n out of nowhere my car started to vibrate n my check engine n tcs lights come on. it only seems to do it when im stopped n then when i start off the car starts to putt or i guess misfire. i went to all the auto part stores around my house to get a helmms manual n they dont have any can someone tell me how i can read the codes my self . thanx
Take it to autozone and have them scanned free.
take it back to the parts store and let them read teh codes. thats the only way.
and you cant buy a helms manual in stores. you have to order it from helms |
the same thing happen to my car last night. I was driving and all of a sudden the check engine light started blinking. Then finally it stayed lit with my tcs light also lit. The car is sputtering and is not responsive. The idle is low and the car sputters at idle as if it wants to shut off. When I accelerate it doesn't want to go.
I took it to autozone and they pulled misfire codes for cylinder 1,2,3,4. Another code for random misfires and lastly it says a code for ignition system & "or misfire" in parenthesis. I changed the spark plugs and they are still throwing the same codes. Last guesses are the coil packs, but all 6? I took it to a shop today, he said it might be the fuel pump. Can misfires occur due to several reasons? meanwhile, I'm still searching old posts. |
Weren't TL's under ignition recalls? Could that be the reason?
BTW - a blinking CEL indicates that continuing to drive could do irreversible damage. You should stop immediately if the CEL blinks. |
i believe that was the key ignition recall. The code that I read today said ignition system. Well, I hope I didn't do too much damage. It's going to be parked now until I can figure this out. Thanks for the heads up.
just borrowed my friends code reader n here r the codes i got 0300 0301 0302 0303 0304 0305 0306 1399 n 1676 can someone who has the code list let me know what these r thanx
P0300/P1399 -Random Misfire
P0301- No. 1 Cylinder Misfire P0302- No. 2 Cylinder Misfire P0303- No. 3 Cylinder Misfire P0304- No. 4 Cylinder Misfire P0305- No. 5 Cylinder Misfire P0306- No. 6 Cylinder Misfire P1676- FPTDR Signal Line Malfunction ( I believe it's related with your PCM/ABS/TCS wires or control system units.) Do whatever you like with this info, as I am just giving you what the code means. Goodluck and don't mention it! |
Ok, I brought it to the acura dealer/stealer.... Charged me damm 180 bucks for spark plugs and a diagnosis. They told me my timing belt is out of timing.
I had just got a timing belt service done else where. So I brought it back to the mechanic that did the timing belt service for me. They take the covers off and find that the timing is all in place. We also did a compression test on all the cylinders with 180psi evenly among all 6 cylinders. Appears to me they did not know what the hell they were doing. They didn't even check my fuel pressure. |
does anybody else know anything about this p1676 code n what else i can do besides change the plugs that could stop it from misfiring. dont want to take it to the dealer n pat out my ass. thanx
again any help at all would be greatly appreciated Jen |
