Low Beam Head Light Bulb
Hi Friends
I need your help.
I have Acura 2000 TL 3.2
Recently drivers side(low beam) headlight bulb got fused.
They are very costly at canadian tire
Can anyone recommend me from where i can buy them cheap and which color should i buy i.e (4000, 5000, 6000, 8000 etc)
Dilawer
I need your help.
Dilawer
Dilawer (04-19-2014)
The following 2 users liked this post by TLZINE99:
Dilawer (04-19-2014),
MrMoAcuraPar (04-19-2014)
06 NBP 6MT TL
The D2S is not much different, it only lacks a reflective strip that the D2R has. D2S is also much easier to find throughout the market. The difference in output/glare that the strip has is negligible. So you can put a D2S or D2C bulb in a D2R housing. Ask me how I know.
Yes the diffrence would be output/glare those strips is there for a reason. U dont want to put D2S Type bulb on a D2R type Reflector headlight assembly (2nd Gen) they would look funky and out of spec. They are mostly used for Projector type headlights assembly (3rd gen)
D2R = Reflector type headlamps (2ndGen)
D2S = Projector type Headlamps (3rd Gen)
thanks friends
highly appreciated for your time and help & suggestion
i will placed the order from ebay link provided by heedehis
but can one tell by checking this link will they are compatible with my car or .......
06 NBP 6MT TL
Listen or not, I do not care, I am just letting you know that there are plenty of options.
I can promise you, as a person who has a lot of experience with these headlights, HIDs, projectors, etc, the output difference is not there. You will not have glare above the cutoff, they will look exactly the same as a D2R. They will not look "funky and out of spec." Yes, D2S are prominent for projectors, but they work flawlessly in a reflector-based HID setup. The unblocked light from the D2S bulb is not going to stray above the cutoff, as the reflector pattern hasn't changed; it still focuses all of the light in the designed manner.
If there is no diffrence GREAT.. i have no prob .....man, those morimoto set up would be nice with 6k.
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
