Immobilizer Reprogram for 6 speed swap
Ok, after searching a bit, I'm still a little confused. I have a working and driveable 03 CL-S6. I have a driveable 02 TL-P. I have keys for both. Going to finish most of the swap this weekend.
After I finish swapping the ECUs: the CL key will work with the immobilizer, but it doesn't fit into the key slots. The TL key fits into the key slots, but the immobilizer won't accept it.
So people say a reprogram is needed.
Does the dealership just (1) take my TL key and reprogram it to work with the CL ECU? Or do they (2) take the CL ECU, and reprogram it to work with my TL key?
If it is (2), they do they just download the codes from my TL ECU and upload them into the CL ECU?
Just want to get as much info before calling around.
did you swap ignitions
I have personal experience with this. I have been doing keys for about a year and a half. For all hondas when you program a spare key or master key or anything. You must first delete all stored keys. Then reprogram the master key and any other keys you will use. As for the remote no idea on that, never done one.
IF you dont do that you will have to have a Honda or acura dealer reprogram the ECU/Key to sync together. That is what i had done. And YES, you will have to bring BOTH keys if you want them to work.
Not true, thats only when you have an "all keys lost" situation. The ecm can old up to six keys at any given time. When programming a new key it adds them to the list. they come programmed with 3 from the factory. 2 masters and a valet. Each PCM has a immobi four digit code for the system. only problem here is that you are using the CL ecm and the TL immobi and ignition. in this case you will need the pcm code for the CL's ecm to accept the immobilizer from the TL. so here is what I would suggest;
1. You'll need to get the PCM code for the CL. you'll need to call an Acura dealer and give them the vin for the CL. remember its a four digit code.(Make sure you explain your situation to them. Dealers are very tight with immobi info due to theft. you might have to show proof of ownership for both cars.)
2. Next you'll need to have the TL towed to a dealer. An HDS is needed to program. because now your car will be seen as a CL when any type of diagnostic equipment is hooked up.
3. At this point they will be able to program the exsisting TL keys to the CL's PCM.
I hope this helps..When immobilizers came into play it made simple ECU swapping very difficult.
*the only other thing i see you possibly having to do is to swap the immobi unit from the CL ignition switch to the TL..This is a longshot because they should be the same. (it's the circular black ring and box around the ignition.)
Well you say that's not true. However i use the tko system. Any time i try to add new keys it forces me to delete the old master keys then add a master key and any new keys afterward. The tl and cl key are the same keys when it comes to the chips inside. So why couldn't he just delete the keys from the cl ecu and use the tl ignition and key and program them into the cl ecu. I don't see why you would have to change or do anything else. With the tko system i could have it done if just a few minutes. Assuming i am correct.
So you are telling me that you can put the CL key in the TL ignition and it turns the car? According to your post you are using the TL key with the CL key next to it. So NO you cant and NO you didnt.
I guess my ignition is the easy girl in town? The TL key doesn't fit into the CL, so I guess I just got lucky.
Either way will work. some prefer to have the dealer do it rather than a mobile key/locksmith. was just offering my advice as i do this everyday....
I see where your coming from now fabricatior. I was just trying to offer up my advice as well. I work for car-mart as a purchasing agent. We can cut and program most keys for $35. Just offering that up as well that there are cheaper routes than the dealer, but we all know that.
No, I CAN and I DID. I was trying to use the TL key with the CL key next to it, but it was a no go. The CL key works perfectly just by itself, with the TL key across the garage.
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
09-28-2015 06:51 PM
