End links problem!!
End links problem!!
I kinda screwed myself because I was able to loosen them up but couldn't get the nuts fully off before the stud started spinning. Any ideas on how to take them off?
and MOOG replacements with bolt to tighten them
thelastaspec (07-14-2015)
Depending if you have enough of the stud exposed, i used a pair of vice grips and was able to hold it while loosening the nut. If all else fails, just cut it off and install your new ones.
DESTRUCTION!!! love the smell of it early in the morning
The things is I don't have new ones to install! Am just trying to take the strut out to replace that, but I guess I'll run to the part store and buy the cheap ones they have in stock
Those should be fun to install!!
Just changed mine a couple of weeks ago. While vice grips are the most common solution, I would recommend a set of needle nose vice grips. A normal vice grip may be too thick to fit in there. Also, tighten that vice grip as much as you can. I used this:
Milwaukee 9 in. Torque Lock Long Nose Locking Pliers with Durable Grip-48-22-3409 - The Home Depot
and it was great for torquing the vice grip versus regular ones where it's a round dial.
cycdaniel
12-17-2019 10:58 AM
marcelft
07-10-2018 06:17 PM
ivegotthenav
09-11-2015 07:51 PM
