End links problem!!
Old Jul 13, 2015 | 07:36 PM
JDMEXI's Avatar
End links problem!!
I kinda screwed myself because I was able to loosen them up but couldn't get the nuts fully off before the stud started spinning. Any ideas on how to take them off?
Old Jul 13, 2015 | 07:44 PM
loulinjai's Avatar
wrench on the nut, vice grip on the threads.
Old Jul 14, 2015 | 03:33 AM
01tl4tl's Avatar
and MOOG replacements with bolt to tighten them
Old Jul 14, 2015 | 09:05 AM
MBP 03's Avatar
If you have enough of the stud exposed behind the nut and nothing else works, you can use a Dremel tool or something else with a cut off wheel to cut the stud.
Old Jul 14, 2015 | 09:57 AM
Alex D's Avatar
Depending if you have enough of the stud exposed, i used a pair of vice grips and was able to hold it while loosening the nut. If all else fails, just cut it off and install your new ones.
Old Jul 14, 2015 | 11:06 AM
01tl4tl's Avatar
DESTRUCTION!!! love the smell of it early in the morning
Old Jul 14, 2015 | 12:50 PM
acutee's Avatar
Use the allen wrench to hold it from spinning.
Old Jul 14, 2015 | 01:09 PM
JDMEXI's Avatar
The things is I don't have new ones to install! Am just trying to take the strut out to replace that, but I guess I'll run to the part store and buy the cheap ones they have in stock
Old Jul 15, 2015 | 10:15 AM
01tl4tl's Avatar
Those should be fun to install!!
Old Jul 15, 2015 | 06:30 PM
wng's Avatar
wng
Just changed mine a couple of weeks ago. While vice grips are the most common solution, I would recommend a set of needle nose vice grips. A normal vice grip may be too thick to fit in there. Also, tighten that vice grip as much as you can. I used this:
Milwaukee 9 in. Torque Lock Long Nose Locking Pliers with Durable Grip-48-22-3409 - The Home Depot
and it was great for torquing the vice grip versus regular ones where it's a round dial.
cycdaniel
Dec 17, 2019 10:58 AM
marcelft
Jul 10, 2018 06:17 PM
Onyxthecat
Oct 18, 2016 02:05 PM
ivegotthenav
Sep 11, 2015 07:51 PM
RK_AcuraTL
Sep 5, 2015 02:26 AM
