DIY:Door peeling (experimental way)
Keep It Simple in
WHAT YOU NEED:
-Gorilla glue or some kind of glue that glues foam.
-TWO pieces of flat wood
-adjustable pipe that you can twist to make longer or shorter.
****SORRY NO PICS OF the PEALING BEFORE
Step 1. Wet the foam first with an ear cleaner and apply gorilla glue to sperated parts.
Step 2. Take piece of wood and press it against the part that is pealing
STep 3. Apply wood to both sides and tighten pole putting enough pressure to seal the peel
STEP 4. Let sit over night AND......
YOUR DONE!!!!!!
YOUR DONE!!!!!!
Keep It Simple in
You might need some tweezers to push down some of the rubber/plastic material that was squished upward on the armrest. Hopefully it lasts for awhile
Keep It Simple in
I agree. I noticed that the material covering your speakers is a little on the darker side. I got ahold of a steam wand and a steam cleaner and cleaned 'em up real nice (all four). Comes out great - you should try it! Take the panel off the door first if you plan on it tho.
I'm confused....Where exactly did you put the glue? I heard that gorilla glue foams quite a bit, so wouldn't it have come gushing out of the two separated parts? I have some gorilla glue, but I'm waiting until spring to fix my passenger rear door.
Keep It Simple in
It foams? Just put the glue on the inside of the peal where the foam is and push to seal the peal.P.S MAKE SURE THE GORILLA GLUE GLUES FOAM AND PLASTIC
Just a quick reply having fixed one of the door handles on my old (now my brother's) 00TL: if the Gorilla Glue foams out from the seam when drying, use an X-Acto knife to simply break away the excess glue- it worked really well when I did the repair > 2 years ago, and it still holds to this day.
Glad to hear it! I'm stoked to do mine once it's warm enough...that and the stupid triangular defrost vent on the left side of my steering wheel. Damn thing is popping out for whatever reason and won't stay down.
Keep It Simple in
i wonder why most get it in the back?
carrying alot of passengers most of the time?
my back interior is mint while the front doors are.. egh...
i'll need to do this to the handles in the front.. thanks!
WHAT YOU NEED:
I did this repair to my rear, driver side door a few weeks ago and am waiting for the glue to cure on the front, driver's door, I thought I'd repeat what Slushyyy said, the glue only needs to be put on the foam (after you wet the foam with water).
Thanks SLushhYYY, i had a similar thought, but chose to work on the arm rest independently. I took the panel off, removed the armrest and also removed the plastic part with the ashtray and window switch. I used your wood idea (I wrapped a cloth around it though) and used 3 C-clamps to clamp the material directly to the plastic foundation of the armrest. I had already purchased Gorilla Glue, so I was glad to read your post and see that is what worked for you as well.
I started out looking a salvage yards for a replacement arm rest and of course, none would sell me the armrest separate from the door panel, AND all the armrests were as bad or worse than the one I had!
Thanks again
Thanks again
No need for wood or anything. Just squirt the glue in and put the c-clamp on the door and the other end in the ashtray or the indention by the window switch...scrape off excess glue after it foams and you're done. you don't need a block if you don't tighten the c clamp enough to mutilate your door.
