Check Engine Light Scan Said PO420
Old 05-26-2004, 09:45 AM
Angry Check Engine Light Scan Said PO420
I went to my friends autozone place and did a computer scan to see what's the check engine light is all about. It came up with:
PO420
Catalsyt Efficency Threshold (BANK 1)
now what da h*ll does it mean?
Old 05-26-2004, 08:09 PM
@ slide or die @
etxxz's Avatar
it may mean you need to either get a new $700 installed catalic converter, get an used one for under $30 at a car dump or very simply RIP THAT S*** out and sell it on ebay or something... get some cash, get a smooth deep truck sound AND free up some HP!!
Old 05-26-2004, 08:13 PM
njtls's Avatar
how many miles on your car?...
and did you install anything electronic recently?
Old 05-26-2004, 11:33 PM
PO420?? your car is high
Old 05-26-2004, 11:35 PM
Seotaji's Avatar
check your sparkplugs, how many miles on the vehicle?
are you sure you don't have a misfire, b/c the fuel isn't burning completely.
one o2 sensor signal isn't matching up with the other maybe.
Old 05-27-2004, 02:02 AM
I currently have about 140k miles, its a 99tlp, A lot isn't it? so what should I do again? Replace catalic converter and what about the o2 sensor? I 'm about to change my spark plugs this weekend.
Old 05-27-2004, 07:21 AM
Seotaji's Avatar
YOU SHOULD REPLACE THE SPARK PLUGS FIRST.
you should replace the spark plugs first to see if that will cure it, which i believe it will since you are 40K over the 100K interval.
replace the small stuff first.
Old 05-27-2004, 01:29 PM
stiletto's Avatar
420... 420... where have I seen that code used before...?
Old 05-27-2004, 02:03 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
i would call acura or find some one with a code book to see what that means before i replaced any thing
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: Check Engine Light Scan Said PO420
