Possible torque converter problem?
Old 01-26-2015, 07:40 PM
Blazin Si's Avatar
My '08 RL has been shuddering and growling at low RPM in 4th and 5th gear. It usually occurs at 1500 RPM (+/- 200 RPM).
It sounds exactly like the problem the 4th gen TL's were having discussed here:
Anyone do the torque converter transmission program recall?
ZachTaylor's thread posted here in the 2nd gen RL forum is somewhat similar:
Strange...trans stays in 4th gear at 30mph, shudders
This is my first car with an automatic transmission, so I'm just guessing here, but it feels to me like the torque converter is oscillating. Like it can't decide whether to lock-up or not.
I tried to grab a video of it tonight. Skip to 30 seconds and the growling/ oscillating tachometer will start shortly after.
I had a trusted Honda mechanic look at it, but they weren't able to duplicate the problem. Probably because they're located in the city and weren't able to get the car into the right conditions for the problem to occur.
If you guys think it's the torque converter, then I'll just drop off the car and tell them to change it. I'm expecting at least couple thousand dollar repair bill. Hopefully it's the TC and not the trans.
Old 01-27-2015, 12:29 AM
Türk's Avatar
Your video is private and we cannot see it.
Go to https://acurazine.com/forums/second-generation-rl-2005-2012-76/transmission-stall-speed-test-906321/
Carry out stall test and share the result.
Old 01-27-2015, 06:11 AM
rlerman's Avatar
The shuddering you note in those gears at those rpms is consistent with a tc issue. Mine shuddered at the bottom of 4th gear, around 37 mph. Never really heard it in 5th. Replaced under warranty.
Old 01-27-2015, 07:15 AM
Blazin Si's Avatar
Go to https://acurazine.com/forums/second-...d-test-906321/
Sorry about that, the video is now unlocked.
I don't hear it or feel it so much in 4th gear. It seems to be mostly a 5th gear problem. It'll start around 35 mph, but the noise is the loudest right at ~50 mph and usually stops after 55 mph.
Old 01-27-2015, 10:22 AM
HEAVY_RL's Avatar
Received 1,041 Likes on 846 Posts
when was the last fluid change for the diff and trans?
Old 01-27-2015, 12:42 PM
Blazin Si's Avatar
The rear diff fluid was changed 2 weeks ago. I don't have any record of the transmission fluid being changed. That's a good idea, though. Wouldn't hurt to have that done as well.
Old 02-02-2015, 03:53 PM
HondaV10's Avatar
Blazin, have you had a chance to do a transmission fluid change? Did it help?
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
Frathora
09-28-2015 11:29 PM
Junior Noboa
09-21-2015 06:28 PM
Quick Reply: Possible torque converter problem?
