Help!! What size battery do we use for a 2006 RL?
I'm trying to find a battery to use on my 2006 Acura RL. I don't want a battery that won't fit flush with the terminals and the plastic? Anyone know a good battery that I can use? The battery I have currently is a no name battery that I can't even read off of. I'd appreciate any suggestion or help Thanks!
Nevermind I found it on their site.
RED TOP :
Part Number: 25 (9025-160)
RedTop®; Battery; BOXED; Group 25; Cold Crank Amps 720; Crank Amps 910; Reserve Capacity 90; Ampere Hour 44; Top Terminal; L-9 5/16 in.; W-6 3/4 in.; H-7 5/8 in.;
I wanted to share what Battery I found finally that seemed to be the best for my dollar..
Gold-Duralast/Battery
For your 2006 Acura RL 3.5L MFI SOHC VTEC 6cyl
Part Number: 24-DLG
Features & Benefits
Duralast Gold has AutoZones highest Cold Cranking Amps and Reserve Capacity ratings per group size. Duralast Gold is designed to meet or exceed your vehicles original specifications. The perfect choice for harsh conditions or high mileage vehicles!
PATENTED POWERFRAME™ GRIDS engineered to be more efficient for optimal performance!
BEST IN CLASS VENT CAPS are engineered to be safer and reduce leakage and corrosion.
SOLIDIUM™ WELDS are designed to stop corrosion and prevent premature failure.
LIFESPAN™ NEGATIVE PASTE is formulated to improve performance and battery life.
Weight: 43.7 lbs
Warranty: 8 YR
Notes: *** 750 cold cranking Amps (935 cranking Amps) *** 130 reserve minutes. -> 3 year free replacement <-
Application: Automobile
Cold Cranking Amps (CCA): 750
Core Charge Applicable: Yes
DIN Designation: BCI or EN Only
EN Designation: DIN or BCI Only
Height (In): 8.875
Height (mm): 225
Length (In): 10.25
Length (mm): 260
Width (In): 6.8125
Width (mm): 173
Weight (Lbs): 44.8
Post Location: Top Post
Reserve Capacity (Min): 130
Right Or Left Hand Positive: Left
Voltage: 12
Part Number: 24-DLG
Features & Benefits
Weight: 43.7 lbs
Warranty: 8 YR
Height (In): 8.875
Height (mm): 225
Length (In): 10.25
Length (mm): 260
Width (In): 6.8125
Width (mm): 173
Weight (Lbs): 44.8
Voltage: 12
Did the terminals fit on the Durlast OK? I remember people saying that finding a battery that would allow the terminals to ft was hard, as the fill caps for the cells get in the way on most batteries.
Chris
Chris
Yeah i want to know about this as well.. I need to get a new battery soon. I keep jumping my car every 2 months lol. The battery costs about 110 in nyc from autozone.
If not Duralast gold, what other battery will fit perfectly with the RL? Because the OEM.
Thanks for future replies
won't the dealer replace your battery for free?
Don't think the dealer will replace it for free. it's a 2007 RL. Bought it used from my friend's brother. I think i read from the other posts that it's a 4 year warranty?
It's still the oem battery and i'm planning a road trip soon lol.
Wondering if the Duralast Gold will fit like the OEM battery so i won't need to use a spacer or any modifications.
ExcelerateRep
10-14-2015 08:20 AM
