Help!! What size battery do we use for a 2006 RL?
Old Feb 23, 2011 | 12:17 PM
Joe's06AcuraRL's Avatar
I'm trying to find a battery to use on my 2006 Acura RL. I don't want a battery that won't fit flush with the terminals and the plastic? Anyone know a good battery that I can use? The battery I have currently is a no name battery that I can't even read off of. I'd appreciate any suggestion or help Thanks!
Old Feb 23, 2011 | 12:26 PM
vtr1000sp2's Avatar
31500-SF1-A1100M - OEM Battery.
Old Feb 23, 2011 | 02:38 PM
Thanks. Anyone know what size for RED Top or Yellow Top optima battery we can use?
Old Feb 23, 2011 | 02:40 PM
Nevermind I found it on their site.
RED TOP :
Part Number: 25 (9025-160)
RedTop®; Battery; BOXED; Group 25; Cold Crank Amps 720; Crank Amps 910; Reserve Capacity 90; Ampere Hour 44; Top Terminal; L-9 5/16 in.; W-6 3/4 in.; H-7 5/8 in.;
Old Feb 25, 2011 | 10:59 AM
I wanted to share what Battery I found finally that seemed to be the best for my dollar..
Gold-Duralast/Battery
For your 2006 Acura RL 3.5L MFI SOHC VTEC 6cyl
Part Number: 24-DLG
Features & Benefits
Duralast Gold has AutoZones highest Cold Cranking Amps and Reserve Capacity ratings per group size. Duralast Gold is designed to meet or exceed your vehicles original specifications. The perfect choice for harsh conditions or high mileage vehicles!
PATENTED POWERFRAME™ GRIDS engineered to be more efficient for optimal performance!
BEST IN CLASS VENT CAPS are engineered to be safer and reduce leakage and corrosion.
SOLIDIUM™ WELDS are designed to stop corrosion and prevent premature failure.
LIFESPAN™ NEGATIVE PASTE is formulated to improve performance and battery life.
Weight: 43.7 lbs
Warranty: 8 YR
Notes: *** 750 cold cranking Amps (935 cranking Amps) *** 130 reserve minutes. -> 3 year free replacement <-
Application: Automobile
Cold Cranking Amps (CCA): 750
Core Charge Applicable: Yes
DIN Designation: BCI or EN Only
EN Designation: DIN or BCI Only
Height (In): 8.875
Height (mm): 225
Length (In): 10.25
Length (mm): 260
Width (In): 6.8125
Width (mm): 173
Weight (Lbs): 44.8
Post Location: Top Post
Reserve Capacity (Min): 130
Right Or Left Hand Positive: Left
Voltage: 12
Old Feb 25, 2011 | 10:36 PM
danmm7's Avatar
How much did you pay for the Duralast Gold? Looks very good on paper.
Old Mar 1, 2011 | 12:20 PM
CFoote's Avatar
Did the terminals fit on the Durlast OK? I remember people saying that finding a battery that would allow the terminals to ft was hard, as the fill caps for the cells get in the way on most batteries.
Chris
Old Jun 29, 2011 | 03:55 PM
aznne0's Avatar
Yeah i want to know about this as well.. I need to get a new battery soon. I keep jumping my car every 2 months lol. The battery costs about 110 in nyc from autozone.
If not Duralast gold, what other battery will fit perfectly with the RL? Because the OEM.
Thanks for future replies
Chris
Old Jun 29, 2011 | 06:47 PM
psheu's Avatar
won't the dealer replace your battery for free?
Old Jun 30, 2011 | 07:15 AM
HEAVY_RL's Avatar
I have a Mexican red top. LoL
Old Jun 30, 2011 | 07:36 AM
EL19's Avatar
LOL hows that holding up?
Old Jun 30, 2011 | 09:09 AM
aznne0's Avatar
Don't think the dealer will replace it for free. it's a 2007 RL. Bought it used from my friend's brother. I think i read from the other posts that it's a 4 year warranty?
It's still the oem battery and i'm planning a road trip soon lol.
Wondering if the Duralast Gold will fit like the OEM battery so i won't need to use a spacer or any modifications.
Old Jun 30, 2011 | 10:46 AM
HEAVY_RL's Avatar
Zero issues in 3 years.
And it dropped right in to the stock location.
Old Jun 30, 2011 | 01:29 PM
EL19's Avatar
Sweet! Thanks!
Old Oct 14, 2011 | 07:01 PM
Wh1t3r0b's Avatar
i bought a group 25 red top and it seems too small...any help here???
Old Oct 16, 2011 | 10:24 AM
racerrl's Avatar
2005 RL
Did you put the spacer on the bottom of the battery? (The one that came with the battery).
Old Oct 16, 2011 | 11:04 AM
Wh1t3r0b's Avatar
yea i got it in and it works great, but there still seems like some space behind it. maybe an inch at most, but the bar holding it down has it pretty secure
Euro4gen
Dec 12, 2015 03:14 AM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
dirleton
Sep 25, 2015 12:25 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
