Failed Smog Test in CA
Old 03-20-2019, 11:40 AM
mayflowerman's Avatar
How do I know if the O2 sensor needs to be replaced vs. the Catalytic converter? The smog shop shows it's the CAT that is failing. E-vap system was good. Have 190k on the car and failing a smog makes the car worth $500 instead of $2500. The Navi player in the trunk is worth $500!!!!
Appreciate any input. Thanks in advance.
Kian
Old 03-20-2019, 11:52 AM
losiglow's Avatar
They still let you guys use gasoline powered vehicles in The Peoples Republic of California? Weird.
Anyways, I'd first try to reset the ECU by pulling the negative battery cable for about 5 minutes then reinstalling. See if the light comes back. It's not terribly uncommon for the downstream O2 sensor to trigger on occasion. I'd also consider taking the car to an auto parts store like Autozone and have them scan for codes. The P0420 and P0430 are for downstream O2 sensors which monitor your emissions.
If the light comes back on, I'd consider first replacing the sensor. Keep in mind, there are two "banks". The P0420 code is the rear bank (1) and the P0430 code is the front back (2). Don't go changing both. Just concentrate on the one that's triggering the code.
Also, if you have one of those codes, only concern yourself with the downstream sensor - not upstream. You could first try cleaning the sensor with some CRC Electronics Cleaner but that doesn't usually work all that well. Replacing the sensor is the next step. With 190K, it could very well just be the sensor. You can find them on OEM Acura websites or even places like Amazon or eBay. I can hunt it down and provide links once you get the code from Autozone so we know for sure what sensor it is that's going haywire.
The following 3 users liked this post by losiglow:
HEAVY_RL (03-21-2019), projektvertx (04-23-2019), RL09 (03-20-2019)
Old 03-20-2019, 01:52 PM
I have the Torque app and a bluetooth module and will try to pull the codes. My lights aren't on. They came on a month or so ago but I think the Acura mechanic I took it to cleared the code. I'll still try what you suggested and reset the ECU.
Old 03-20-2019, 02:57 PM
losiglow's Avatar
That's the way to go. The Torque app is great.
Yeah, let us know the code and we can go from there.
Old 03-20-2019, 03:07 PM
Fk no!TheyldstroyEvrthing
RL09's Avatar
Like he said. It may be the sensor needs replacing but the code for the cat will come up as well.
If so change sensor, all with go away.
Old 03-21-2019, 01:12 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
I've got $500 when it fails again.
#callme
Old 03-21-2019, 04:52 PM
schen72's Avatar
Back when I had my TL, the cat was slowly dying. It would occasionally throw a CEL. In CA, any CEL is an automatic fail. So for about 4 years (2 smog tests) I was able to clear the code using Torque, drive around for about 50 miles which "resets" everything, and it would pass the test. Over the course of 4 years, I noticed that the CEL would throw a code sooner and sooner, when eventually it would throw the code almost immediately upon clearing it. That was my indication it was time to finally pay for a new cat.
Old 03-22-2019, 05:17 PM
Torque app says there are no faults to clear on ECU. In the Emissions Readiness s/DTC screen in the app, the Catalyst shows in Red as Incomplete. Everything else is Green and Complete.
Error code on the Navi says P0420 but that was dated a year ago (2/17).
I drove the car about 10 miles and still the same. I'm guessing I need to drive more to help the CAT reset or the ECU to reset.
Old 03-22-2019, 06:16 PM
schen72's Avatar
After I cleared the code manually, I had to drive it around 50+ miles.
Old 03-24-2019, 01:33 PM
Just drove the car about 50 miles and the Cat was cleared. Time to get the smog check.
Old 04-02-2019, 06:45 PM
Passed smog check.
Anyone want to buy a 2005 RL?
Old 04-23-2019, 11:36 AM
thisaznboi88's Avatar
500 dollar? Lol
Old 04-23-2019, 06:28 PM
projektvertx's Avatar
Passed smog check.
501$? Lol but seriously, if it’s actually for sale, please make a FS ad in the marketplace
Old 04-24-2019, 07:22 PM
Thanks projektvertx. Just listed it.
projektvertx (04-24-2019)
DarkNinja75
1G TL (1996-1998)
11-26-2009 02:20 PM
tmnhs81
09-23-2009 07:59 PM
irresponsiblekid
09-22-2009 04:38 PM
ChicagoRuss19
1G TL Problems & Fixes
09-08-2008 08:30 PM
Quick Reply: Failed Smog Test in CA
