Driver door handle won't lock when I touch the dimple..
Yup anyone have that problem? When I hover my hand inside the handle it will unlock, but when I try to touch the dimple on the driver side door, it won't lock. But on the passenger side, it will lock when I touch the dimple. Just see if any of you have that problem? My remote still works though.
I've had both door handles replaced TWICE for the same issue. Problem was chronic after handwashing or going through a touchless car wash.
Last one was replaced three months ago. So far so good.
Originally Posted by KB1Spec
So you think water might seep inside the handle?
I had my driver's side handle replaced a year ago and have had no issues since. The passenger side has always worked.
*Raises hand* Yup, I've had the issue on the driver's side and it was replaced under warranty. I expect it to need replacement again at some point given the experience on this site. This is why I have an extended warranty.
have never seen anyone complain about door locks other than 05
mine is 05 and after replacement, it works flawlessly. Ever, ever so rarely I may have to touch twice (probably missed the dimple). Cannot recall ever having to touch unlock twice.
Originally Posted by getakey
have never seen anyone complain about door locks other than 05...
LL
Anyways, going to the dealer this weekend and check on the problem. I thought I was the ONLY one here with that problem.
Is there a way to prevent it to happen again if I wash my car? Thanks.
Mine is an '06, and as I said, I'm on my third set (replaced twice).
When I wash the car with FOB in pocket, the car will lock or unlock repeatedly as handle gets wet. Simple solution is put FOB in car when washing. However, I do not have any problem symptoms after washing the car, so I don't worry about it.
I think the "wash" problems are more pronouned, i.e., linger if you go thru a power wash.
If you search the Forums, someone had posted a thorough explanation of the technology and why water has an effect
Tuna - seems very odd that yours continues to fail. The water problem is very temporary as in minutes after washing the problem is gone. I wash the car every week.
As I said after replacement (once), mine is flawless. I barely have to touch the dimple to lock or unlock.
Just to update what happen. I got it to work last night. For some reason, I just dab liquid wax on a towel and wipe it onto the handle. Then for some reason I was able to touch the dimple and the door was lock. I dunno what I did but it work for some reason.....strange.
According to my cousin (he being an Acura mechanic) was telling me that the 2005 RL has a lot of problems with locking the doors, but not unlocking. I know that mine does not lock the doors (only once has it happened and on the passenger side only).
Looks like I'm going to need to get mine replaced. When I bought my car it would only unlock...one time I SWORE it locked itself when I got out...but I thought I was crazy, I had no idea it would lock too...I guess I should take it in.
I don't think it is a matter of water getting into anything in the door/handle. Someone posted a link to an article that explained the technology and what happens when it gets wet. I cannot find it right now.
Yes i read that but from what i see water does get in there and if water did not get in then there wouldn't be a problem.They are made to get wet and dry out just like inside your door. I have worked for Honda and no longer do because they dont care about you or your car. The people that care are in japan where they take pride in what they do thats where Honda and Acura were born. I have been put down so many times for driving a HONDA but now north america is changing Toyota is at the top now only to be followed by honda i hope and show all that imports are the best exspecialy Honda!
I havent gone through that problem yet.
