Check emissions system light...
Old Aug 8, 2016 | 07:09 PM
Ratheruneeq's Avatar
This light has been coming on and off for some time now, Im guessing o2 sensors need replacing? How many are there? 2 or 3?
In at 119k
Old Aug 8, 2016 | 07:36 PM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
Check oil level; battery cables.
Old Aug 8, 2016 | 11:09 PM
Maintenanceman's Avatar
And air cleaner.
Old Aug 8, 2016 | 11:14 PM
oo7spy's Avatar
What are the OBD codes?
Old Aug 9, 2016 | 11:14 AM
08KBP_VA's Avatar
Pull the codes then ask for interpretation!
Old Aug 9, 2016 | 12:55 PM
how do i pull codes on these cars.
Old Aug 9, 2016 | 01:51 PM
RL09's Avatar
Code scanner. or drop by a shop they all have one. they'll probably charge a twenty.
Old Aug 9, 2016 | 04:56 PM
08KBP_VA's Avatar
Definitely not at a dealer, maybe $120.
Havent pulled codes in either of my acuras but I have a general obd2 reader and presume it works the same way on acuras, hook up to obd2 port and go. If so and you trust the big box autoparts places they should be able to read the codes. They are however prohibited from clearing them at least in VA and now I think they arent even allowed to hook it up, you have to do everything but its free and will get you in the ball park with the issue closer than we will without the codes
Here is a link to some common codes. Good luck
RL 3.5/3.7L ? MDX 3.7L (2005 ? 2009) ? OBD Trouble Codes
Old Aug 9, 2016 | 06:00 PM
oo7spy's Avatar
The box stores can read the CELs because they are standard Honda codes. The proprietary systems like SH-AWD won't be picked up.
You should be able to pull the codes from the message inbox in the nav menu. Is there an envelope in the top right corner of the nav screen?
Old Mar 20, 2018 | 07:36 AM
RL09's Avatar
I got this light yesterday. I was not happy. Then remembered this thread and looked this one up https://acurazine.com/forums/second-...-light-698543/ .
I opened the gas cap and then retwisted it and did 4-5 clicks. I have a bad habit of just stopping as soon as it clicks. Seems on Acuras there's a TSB on this. bSo, you gotta click 4-5 times. Air tight = no O2 = after a few ignitions during the day, it was gone.
Hope this is helpful for others.
Old Mar 23, 2018 | 08:39 AM
ksu1018's Avatar
there are 4 oxygen sensors. 2 upstream which are located on the exhaust monifolds and 2 downstream that are on the exhaust pipes by catalic converter.
Old Mar 24, 2018 | 09:05 AM
projektvertx's Avatar
Ahh good ol' gas cap
Old Sep 3, 2018 | 03:00 PM
JD8's Avatar
JD8
In my case the positive terminal of the battery was slightly loose. The check emission system message went away as soon as I tightened it up. Strange message for a loose battery, IMO.
gavriil
Apr 1, 2026 12:45 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
MDXOKIE
1/2G MDX (2001-2013)
Sep 4, 2016 08:02 PM
Aquaholic
Sep 4, 2016 04:46 PM
Midnight Mystery
1G RDX (2007-2012)
Mar 22, 2016 12:16 AM
