3rd brake light not working.
Old 04-01-2013, 05:17 PM
bd1980's Avatar
I was behind my wife and the third brake light is not working at all. I popped the cover and it's connected just fine. I noticed in another post somebody said they replaced the switch for the brake pedal but I can't seem to find it the switch. Help please!
Old 04-01-2013, 05:19 PM
8th Gear
92BlkTy's Avatar
OEM BRAKE SWITCH ACURA 02-2009
36750-SMA-003
New number I hear is 36750-SJA-013
Old 04-01-2013, 05:22 PM
getakey's Avatar
Wouldn't the switch control all the brake lights?
Old 04-01-2013, 05:26 PM
Carbon Legend's Avatar
brake switch is located at the pivot point under the dash. should be a 2 pin connector attached to it
Old 04-01-2013, 07:00 PM
bd1980's Avatar
Thanks for quick responses! Do they sell these at auto zone or anything like that so I can get it quick? I don't want me or her stopped. Just got the windows done and I know they would probably say something to have it removed.
Old 04-01-2013, 07:26 PM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
Most people found the connection was just loose. You can also just pop off the CHMSL housing and check the connection there too. Use your fingers to pull it down.
Old 04-01-2013, 07:34 PM
bd1980's Avatar
That's the first thing I checked. Very tight.
Old 04-02-2013, 10:28 AM
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
That's what I would have thought, too. I assume the other two brake lights are working. Is it possible the light or its connection is just burned out? Unusual but possible.
Old 04-02-2013, 06:03 PM
sj993's Avatar
The brake light itself probably went out. More common than you might think. Happened to mine, I ended up replacing the entire light since it is LED, you cannot replace part of it. Price was around $100, but it works fine now.
ichi d (04-02-2013)
Old 04-10-2013, 10:08 PM
bd1980's Avatar
Just a quick update guys... I ordered the part from rockauto using the part # from 92 blk ty, cost 12 bucks after shipping. Works perfect. Thanks again, this forum is great!
HEAVY_RL (04-10-2013)
Old 03-10-2019, 06:23 PM
5th Gear
GregPayne's Avatar
The LED is almost always NOT the problem. The problem is the brake light switch just above the brake pedal. The part number is 36750-SMA-003. You can buy it at an Acura or Hondy dealer for about $11. Autozone also has it for $10 under part number SW6271. Here’s a YouTube that shows how to install it.
. It’s very simple!
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
brandnewcolony
09-12-2015 10:39 AM
cruisingnycfl
09-02-2015 12:11 PM
Nicho863
09-02-2015 08:12 AM
Quick Reply: 3rd brake light not working.
