2014 Acura RDX Front Windshield Haze/Scale
Gentlemen,
Need some help with this one. I have tried CLR, Bartender's Friend Paste, Windex, Spray 9, Denatured Alcohol, etc. Still, this haze takes over my windshield when my wipers operate. I have also attached a picture with my defroster turned on and you can see this scale pattern forming, which is the exact pattern that is on my windshield. Vehicle is a 2014 RDX and this is my 2nd windshield (first one took a nasty rock). The windshield was perfect when I got it less than a year ago but after this winter this haze is back with a vengeance. My OEM windshield did the exact same thing with the hazing/scaling. Any suggestions on what is causing this and how to remove it. I should tell you that my wife a 2017 CRV whose windshield is perfect and she parks in the same driveway.
Is the haze on the inside or the outside?
I would suggest two things:
1. Change your wiper blades.
2. Clean the haze off with your favorite glass cleaner and apply Rain-X.
Do you think the Rain X will help prevent the formation of that pattern? It almost seems like water is sticking to my windshield after the wipers make their pass
I feel like my windshield at this point is definitely clean and the water seems to almost be sticking to the windshield in that haze pattern. I am tempted to use Rain X just for the heck of it and see if it makes a difference or changes the pattern on the front windshield. If it does change or help the pattern then I know it is an issue of water sticking rather than something being on my windshield that I can't remove.
Suggest you clean windshield with a cleaner that will remove wax buildup such as used to clean floors. Maybe something like Varsol or similar. Maybe bug and tar remover.
Try on a small area of the windshield out of the line of vision with a cloth or paper towel dampened with the wax remover so it does not run into unwanted areas.
And keep it off the paint finish or you will be re-waxing the car.
If it works, use it on the rest of the glass.
I can`t think of what else would cause the issue and I have seen it myself on my own vehicles and regular glass cleaners do not take off the wax build-up..
Clay bar it!
I wouldn't be to concerned with the solvent on the windshield glass itself, as it is glass and there are not to many things that will eat/etch the glass. I would be more concerned with the cleaner damaging the paint, plastic parts, or seals/gaskets around the windshield.
Update on this - - I went ahead used Rain X just for the heck of it and replaced the wipers... So far so good! I have not had the water form in that weird haze since I applied Rain X. I will keep everyone updated as I continue to drive more in the rain.
So after 1 month of driving in the rain / wet conditions, I can say with 100% certainty that the Rain-X did the trick. My windshield is flawless! Thanks everyone for the help!
