Schnitzel and Tea & Crumpets
After six years of babying this great car, I'm finally going to put in some work in.
Just purchased a Comptech Supercharger Kit today!!!! The previous owner was kind to throw in some goodies too; see parts list below:
CT S/C w/ 7lbs pulley
Greddy E-manage Blue
AEM Water/Meth Kit
AEM C.A.I
CT Headers
Thanks to the IRS & tax returns , I have some funds to play with it and ordered additional parts from www.horsepowerfreaks.com; see below:
Ralco RZ Aluminum Pulley Kit
Aasco Lightweight Flywheel
Unorthodox Sport Pro Unsprung 6 Puck Clutch Kit
Tanabe NF210 Springs
Ordered a short shifter kit from JTC Customs (http://www.jtccustoms.com/store/show/CL%202SS)
I'll start posting pics this weekend to document the entire project from package deliveries to turnkey test drive.
Something tells me my wife isn't going to like this! Lol
Stay tuned!
AEM Water/Meth Kit
AEM C.A.I
CT Headers
Stay tuned!
Marcelechka (07-27-2012)
Thanks for the heads-up civic.
In other news, I picked up my new battery (51R) from Advance Autoparts for the install tomorrow. Surprised at how much smaller it is versus the stock spec. Spent $139 on it, but I'll get $13 back when I return the old one.
That's $13 to offset that restocking fee
civicdrivr (07-27-2012)
I only have $2.4k left to play with... considering tuning & suspension that is still needed, I can't afford any more errors on my part.
Suggestions are greatly appreciated!
Horsepower Freaks still says its for the 2.2/2.3l engines. If the CSR steered you towards that clutch, fight for the full amount back. They fucked up.
Unorthodox does not have a clutch for the J series.
Dove right into the HPB with tune. A couple months later, I ordered the 3.2" pulley from South Florida Pulley. Others here went with the 3.3" s/c shaft pulley & 3.275 alternator configuration. I went with the 3.2" to gain back the [slight] pressure loss due to the IC piping. As of now (depending on weather), I'm seeing +/- 9 to 10lbs on the gauge... Typically in the early morning when it's cool out & there aren't any cars on the road, wheels break loose in 2nd at WOT. Which speaking of, I need new / better stickies
The meth plays a bigger role than many would think; the intake manifold along with the IC piping is ridiculously cold to the touch... like really cold... to the point with it gets sweaty lol
You're some what local; I'm down to meet up one of these days to check out your whip
The kit comes with two led injection status lights which tells you if: low fluid, staging, initial, & full spray.
See kit details below:
Snow Performance Stage 2 Meth Injection Kit
gnuts (09-03-2013)
Thanks Mas.
By the way......i am not 100% percent sure as i am not an expert in this type of modding but i believe you will want to mount that solenoid really close to the injection point on the intake pipe for 2 reasons. 1) when you finished flooring it the solenoid closes and the rest of the line from the trunk to the engine bay is still filled with meth and it gets sucked in which is the reason to have the solenoid in the first place. 2) when you do floor it again now you will be waiting for the pump to fill that part of the line downstream of the solenoid before it actually reaches the intake pipe nozzle. If you place it really close the to injection point (i had to redo mine as well) then the meth injection will be more immediate with less lag because the lines will already be primed and you will not be sucking it and wasting meth once your done flooring it.
Once again i'm not a meth kit expert but i am an engineer and that is the only way it makes sense to me.
Also i used the wiper tank as my meth tank and i love it because everything is in the engine bay and no lost trunk space. Something you may want to look into if you are already moving the solenoid up front to. I've got pics and info on using the wiper tank if your interested too.
So back to the HBP, just bought mine. Not ready to install yet because i need to resolve a CEL that gives me a slight studder during closed loop but once i get that resolved HBP should be going on. Lets see how it goes.
Anyways, lets try to get together and compare notes.
Looking good Cel
Regarding tuning for meth....ideally you get it tuned to:
1) to make sure meth is kicking in the right amount (make sure ur using the right nozzle size per kit instructions) and to make sure it is being triggered at ideal time for optimum power.
2) theoretically your tuner can now squeeze out a little more power (advanced timing and such) because you have the meth kicking in to eliminate knock potential.
All that being said, you dont HAVE to get tuned again is you are satisfied with how its running and feel no issues or power loss.
PS----my "I'm not an expert" disclaimer still applies
CL-Future (09-03-2013)
Yeah I forgot to add the part about the timing, good point, although the ECU can auto-adjust that based on what it detects. Since he mentioned the manifold is now cold due to the intercooler and water/meth, I'd be surprised if he's not getting the most out of the timing, but I could be wrong. I think some tuning software can also active it based on rpm vs psi...
I've since installed the correct nozzle (175ml/min - 250 to 375hp).
In regards to when to start spraying, the tuner assisted with that. Do note there is not software for this particular meth kit. It's either on or off (initial & or full disbursement of course).
Regarding the timing, this particular piggyback does not advance, it can only retard
As the Emanage unit is dated and limited in it capabilities, it works for the current application with no issues which is add & remove fuel when needed.
I was reading about the snow meth kit and it talks about the benefits of spraying before the blower on our type of supercharger. any thoughts on this?
if you use the windshield reservoir, can you put in a small reservoir somewhere to still have some washer fluid?
IMO I don't believe spraying before the blower would be beneficial as it could very well lead to actually damaging it... I haven't read anyone on here ever doing that, so I couldn't tell you?
Regarding the windshield reservoir, you could totally do that if you find the space... it's super tight in there to begin with
We located the battery below the the blower; easily accessible to give or get jumped
How your build coming along?
I read in the FAQ section on the snow meth site about spraying before the blower. I was just curious. I'm thinking about doing a meth kit in the spring but we'll see. The car drives great right now and needs nothing. But I'm getting that itch again. HBP and meth?
Yeah, once you get the itch, it never ends from there lol
Marcelechka (09-24-2013)
The following 2 users liked this post by Marcelechka:
97BlackAckCL (09-30-2013),
gnuts (09-27-2013)
I believe you are correct. Also, you can't see it from the angle in which the picture was taken, but there's piping connected to the throttle body, which connects to the 90 coupler bend.
gnuts (09-28-2013)
From the research i have done on the comptech blowers the ones with the black casing are an older design while the silvers are a newer one. I wondered the same thing as you until i ran across the answer on this forum a long time ago
Right now im using a custom ram air type that came with the blower and all it does is suck hot air in. Was planning on makeing a custom one
I was going to go with 3.5 inch. ..Any reason you went with 4" richkid?
Was going to get the silicon and aluminum tubing off this site siliconeintakes.com
