UR Crank with the Supercharger
Old Mar 6, 2004 | 07:53 AM
scalbert's Avatar
I have been asked about running the UR crank pulley with the SC kit and finally decided to run the numbers. This is just for the UR under drive crank pulley which is smaller than the stock crank pulley.
When the UR crank pulley is used with the SC kit, the blower would be turned only slightly faster than the engine even with the HBP. So you would only be making about 1.6 PSI boost. This would give up about 30 - 35 WHP at this low of boost; or the majority of the gain the SC provides.
Here are the numbers for the Accessory Belt (in millimeters):
Stock Crank / Alternator Side
175 / 67 = 2.612 Ratio
UR Crank / Alternator Side
141 / 67 = 2.104 Ratio
Here are the numbers for the SC Belt:
Base Pulley / SC Pulley
76 / 100 = 0.76 Ratio
HBP / SC Pulley
83 / 100 = 0.83 Ratio
To determine the final ratio, multiply the two values. For example with the standard SC kit:
2.612 * 0.76 = 1.985
In this case the blower is turning 1.985 times faster than the engine. This can be directly correlated to boost since it is a positive displacement blower.
For another example, using the HBP and the stock crank:
2.612 * 0.83 = 2.168
Using the UR crank pulley and the HBP gives the following ratio:
2.104 * 0.83 = 1.746
Obviously slower than even the base SC pulley with the stock crank. Here is how you use these ratios to determine boost. Since it is a 62ci blower it moves that amount every revolution. But since this is a four stroke engine, a cylinder only ingests every other revolution, we have to take half of our displacement. Half of our 3.2L in cubic inches is about 97.5ci.
To calculate the theoretical boost you use the following formula:
62 * Ratio / 97.5 * 14.7 - 14.7 = Boost
Where 62 = the blowers displacement
Ratio = the drive ratio
97.5 = half of the engine’s displacement
14.7 = the assumed atmospheric absolute pressure
For example with the base SC kit
62 * 1.985 / 97.5 * 14.7 - 14.7 = 3.86 PSI
That 3.86 PSI boost is about correct with the base kit. Here it is with the HBP and stock crank:
62 * 2.168 / 97.5 * 14.7 - 14.7 = 5.57 PSI
Which, once again, is about right.
Now for UR pulley with the HBP:
62 * 1.746 / 97.5 * 14.7 - 14.7 = 1.62 PSI
IMO, it is better to stick with the stock crank pulley.
Just for fun, here are the numbers with the base SC pulley and the UR crank pulley:
62 * 1.599 / 97.5 * 14.7 - 14.7 = 0.25 PSI :o
Old Mar 6, 2004 | 08:13 AM
typeR's Avatar
what about the UR crank pulley that doesnt under drive made for the SC application just 6 lbs lighter weight
Old Mar 6, 2004 | 08:18 AM
scalbert's Avatar
If it it the same size then the stock numbers would be used. I mainly spoke of boost which is independant of weight, just size.
Old Mar 6, 2004 | 08:57 AM
ModAddict's Avatar
I always wondered, and was recently asked buy someone interested in the blower that has the UR underdrive pulley. By your numbers the UR underdrive crank pulley is 20% smaller, but the final boost difference is 93% less.
Old Mar 6, 2004 | 09:11 AM
scalbert's Avatar
Yep, it is that multiple ratios and the heavy depepandance on the crank which play a part. But most importantly it is the aspect that the blower speed has to be greater than the engine speed by a good margin in order to make boost.
You need a minimum of 1.57 times the engine speed to make boost. If you are running the blower twice the engine speed and reduce this by 20%; you end up with a 1.6 ratio. That has changed the boost making potential, as you stated, 93%.
What a huge impact and it goes to show that small overall changes have a dramatic affect on boost.
Old Mar 6, 2004 | 09:14 AM
ChucksTL_RENAMED's Avatar
Calculations well done Steve..
Old Mar 6, 2004 | 06:58 PM
typeR's Avatar
im sorry i thought from the context of what you wrote that you were just putting out the data on the UR pulley to show the negatives of what will happen when using the 2 together...i meant what i said as if to suggest that you werent aware of a non under driven version...
Old Mar 6, 2004 | 07:00 PM
scalbert's Avatar
I understand and do appreciate the help and insight.
Old Mar 6, 2004 | 07:02 PM
typeR's Avatar
since we're on the subject...what do you think about the non under driven ur pulley for sc'd or non sc'd cars for that matter?
Old Mar 6, 2004 | 07:04 PM
scalbert's Avatar
I can't say for sure. The SC would put an additional load on the belt drive system which was never accounted for. I don't think it would be an issue though.
Old Mar 6, 2004 | 07:41 PM
power3dfx's Avatar
Parting out 02 Type S :(
scalbert, thank you for clearing this topic up. i called comptech and UR, both said the boost would be so low that it would defeat the purpose of the SC
Old Mar 7, 2004 | 12:06 AM
darrinb's Avatar
///M POWER
UR makes a crank pulley if u have the blower
Old Nov 10, 2007 | 05:20 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
This thread has been brought to my attention so I thought I would do the same for everyone by bumping it
Old Nov 10, 2007 | 04:31 PM
SIRSIG's Avatar
THE J35A2...
ADHD just kicked in yo!
Old Mar 17, 2008 | 08:45 AM
Nitin's Avatar
But I just got here
Bringing back this old thread because I have a question about the supercharger and crank pulley. I have the UR underdrive crank pulley and am getting the supercharger installed tomorrow. Can you change the crank pulley without having to remove the supercharger? I was going to order the UR stock diameter pulley and get it put in later this week.
Old Mar 17, 2008 | 08:51 AM
Moodist's Avatar
I think you should be able to do it, because the pulley is accessed via the bottom of the car.
Old Mar 17, 2008 | 09:21 AM
Nitin's Avatar
But I just got here
Thanks Moodist. Anyone know for sure? If I have to, I'll just have them put a stock pulley back on. But I'd rather wait and get the UR pulley if I can.
Old Mar 17, 2008 | 09:33 AM
Excelerate's Avatar
Former Sponsor
Yes you can install the crank pulley separate from the supercharger.
Old May 23, 2008 | 03:13 AM
Took the liberity and calculated some boost levels for each pulley should someone upgrade to the MP90 unit Pretty interesting stuff.
UR Crank pulley/ Alternator Side
Planning on running these ratios:
3.0V6 base pulley (2.83")
71.9/100=0.719 Ratio
Base Pulley(3.0") / SC Pulley
76.2 / 100 = 0.762 Ratio
HBP (3.28") / SC Pulley
83.3 / 100 = 0.833 Ratio
Second final ratio is using the UR S crank pulley with identical alt. pulleys
2.83" pulley 2.612 * 0.719 = 1.878/1.51 = 2.85psi / MP90:10.78/ MP90+UR: 5.79
3.00" pulley 2.612 * 0.762 = 1.990/1.60 = 3.90psi / MP90 12.30 / MP90+UR 7.01
3.28" pulley 2.612 * 0.833 = 2.176/1.75 = 5.64psi / MP90 14.83 / MP90+UR 9.08
Old May 23, 2008 | 05:13 PM
krisdlm's Avatar
Lives On BOOST
interesting...
Old May 23, 2008 | 08:21 PM
Allout's Avatar
Blown is Best
Is upgrading to the MP90 even possible without serious fabrication?
Old May 23, 2008 | 09:34 PM
jproy's Avatar
MP90 uninstalled
I compared the specs on the magnison site and it would require some serious fabrication
Old May 23, 2008 | 10:08 PM
I've been going around to some blower shops and asking around, imaginegetting another half liter out of each revolution of the rotors
PLus Doug from Hondata always thought the MP62 was small for our cars, im split on it, would be nice to work out and perfect however
Old May 23, 2008 | 10:19 PM
Allout's Avatar
Blown is Best
If it could be done, you could get a lot cooler charge with less boost and similar flow. I haven't seen a map of a MP90 to see where it's efficiency range is compared to the MP62.
Old May 23, 2008 | 10:24 PM
Exactly thats the point
MP62
MP90
MP62
MP90
Old May 23, 2008 | 10:46 PM
Allout's Avatar
Blown is Best
Whipple Supercharger is in my town. I should go visit them and see what they think. They tuned the Ford GT of a guy I know and it's putting down over 1000HP on 91 octane and still meets CA Smog.
Old May 24, 2008 | 12:29 AM
jproy's Avatar
MP90 uninstalled
I would love to see this motor with a MP90.
Old May 24, 2008 | 02:09 PM
haha go ask
Thats pretty impressive, I bet the GT is rated at EV (Emission Vehicle)
acuratl26
Apr 23, 2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
