Door panel...arm rests!
Old 09-06-2011, 09:59 AM
elacura02's Avatar
Has anyone had an issue with the door panel arm rests separating from the plastic piece where the power window buttons sit? I'm having separation on both driver and passenger side. Anyone have a fix? Anyone have to order if so from where and what price?
Old 09-06-2011, 10:04 AM
harvthesecond's Avatar
Like this?
I think the only real fix is to replace the panel.
Harv
Old 09-06-2011, 10:06 AM
fuzzy02CLS's Avatar
Look at the FAQ. I think it's in there how to fix it.
Old 09-06-2011, 10:15 AM
elacura02's Avatar
Yes, exactly like that...it bugs me to see it. Harv, did you order yours?
I will continue to look on FAQ's...
Old 09-06-2011, 12:49 PM
fuzzy02CLS's Avatar
Edit HERE....
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/diy-my-interior-issue-485828/
Old 09-06-2011, 01:16 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
theres no magical trick. u gotta remove the door panel and glue and clamp that POS in place.
I don't even use that frigging arm rest and it still came loose like that.
I just used some quick set glue held it there for 5 mins and then it held.. but it aint perfect.
but it didn't bother me enough to warrant the full shAbang.
Old 09-06-2011, 01:59 PM
Originally Posted by fuzzy02CLS
Thanks for the link. Looks like my next weekend project, now to find an open weekend to do it.
Old 09-06-2011, 02:35 PM
elacura02's Avatar
fuzzy...appreciate the link! I will bookmark for sure.
harv...my thoughts exactly, might try something different first.
Especially since my contact said $75 each.
Old 09-06-2011, 06:36 PM
ddecerchio's Avatar
looks like i found something to do this weekend lol
Old 09-07-2011, 06:04 PM
4th Gear
rkmj's Avatar
Mine began to separate a two years ago. I took the door panels off, re-glued them and clamped them. Unfortunately, they have started to separate ever-so-slightly. I used upholstery glue last time. This time I may use something a bit stronger. It seems that the more time the car spends in the sun without interior protection, the quicker they come up. They were coming up on my friend's car years before they began to separate in mine. The fix is relatively easy as long as you have a bit of patience with the door panels, they can be a bit of a hassle to get off cleanly. Good luck! I'll be out there doing it again soon!.
mlody
12-04-2019 02:11 PM
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
soupi
14
11-15-2015 11:15 AM
Jimmy_D
10-07-2015 11:52 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
Quick Reply: Door panel...arm rests!
