Anyone have a bored Tb/3.5-4' intake setup? Need help
Old 08-06-2017, 11:27 AM
Soseductivesf's Avatar
Good morning! So I have a CLS6, mods include CT headers, MDX spacer, p/p manifold and runners, blox 74mm tb, p2r tb spacer, and 4' custom intake. I'm having problems finding hardware to hook up the iacv. (Need pipe fittings but haven't found them yet)If I bypass the iacv, it throws a code for iacv failure. Anyone have a solution for this?
Old 08-06-2017, 11:28 AM
Old 08-06-2017, 03:03 PM
Received 1,736 Likes on 1,392 Posts
Originally Posted by gnuts
The issue with those throttle bodies is the IACV (idle air control valve not Ivac) needs air before and after the throttle plate. So you need to figure that out. I thought some TB spacers had a threaded hole for just that.
It appears that gnuts has answered your question regarding the blox TB IACV matter in your other thread.
https://acurazine.com/forums/second-.../#post16068802
Old 08-06-2017, 04:42 PM
If you don't have one of these already, maybe it will help?
B Series Throttle Body on J32A2 Intake Manifold
However, I'm not sure it will work with your Blox TB.
I found a Blox discussion on the thread below:
https://acurazine.com/forums/2g-tl-p...e-body-893800/
Old 08-06-2017, 08:07 PM
3.5 psi
gnuts's Avatar
You can get vacuum bungs online for before the throttle body into your intake, then I would tap a hole in your spacer or neck of your manifold. Maybe you could simply T into a vacuum line off the manifold at the rear?
Old 08-15-2017, 01:18 PM
Not sure if the blox tb is going to work. The bracket broke when test driving it. Really want to have the iacv work but may have to bypass it.
Old 08-15-2017, 01:58 PM
I Wanna Beer
TheWeez's Avatar
Seems an oversized TB. Has to kill throttle response for no real benefit. These engines aren't starved for air even with the stock TB.
Old 08-22-2017, 05:20 PM
Lone Wolf
brian6speed's Avatar
Mount iacv separately with a aluminum plate or use a k-series tb like me with iacv at stock location.
Old 08-22-2017, 05:23 PM
Lone Wolf
Nope, not oversized. Did not affect my throttle response. I'm guessing you have not tried it.
I gained 12 peak hp with j37 IM and 74mm TB over bored oem tb, ported IM, MDX velocity stacks, and P2R plenums. My new IM is also 10-15 lbs lighter.
Old 08-24-2017, 02:11 AM
Got it to work and used the aem a/f controller but I think I'm going to need something different in the long run. Gonna leave it alone for now and do the final drive upgrade, change the motor mounts and subframe(found a 6speed subframe locally for 325). My 4" intake is a short ram one with a heat shield. Definitely felt the difference and almost feels like a Q50. Almost lol
Old 08-24-2017, 06:44 AM
If you could provide a little detail, that would be great.
This will be interesting as well. Don't forget to update your other thread with the specifics.
