Acura Scan Tool same as OBD2 tool?
I'm getting really irritated at my car's issues. The dealership still has no clue what is going on with my car. No error codes are being thrown yet the car is driving pretty bad. It surges/sputters during acceleration, it shakes when I get on/off the throttle, Throttle response is delayed when I get on or off it, idle is slightly rough even though I already had the IAC valve replaced.
So I want to start doing my own investigating, and replace the smaller inexpensive parts that could cause these issues after I check them out myself.
I was going through my Helm's service manual and all over the place it says something like "check using scan tool"
My question for you guys is, are they refering to an OBD2 tool?
If so, is there one that you guys recommend?
I really would like to do what I can to be able to keep this car because it is nice car and my trim is the rarest. I know if I ever had to trade it in or sell it i'd kick myself in the arse the day after.
Of course after I posted this, I went through google to search for some answers and found this on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
Originally Posted by mrsteve
Yeah so you pretty much answered your question there. No it is not the same device.
an OBD2 reader will simply report certain values to me, whereas the scan tool does it all?
A scan tool will report back to you things like throttle position, IAT, coolant temp, etc.
Some tools only report DTC codes (things associated with a CEL) some will show all the data I described.
The Honda tool you linked on eBay is a dealer tool that we really have no use for.
During misfires it would.
I guess I'll probably be [checking|replacing] the coilpacks for starters too.
The other thing I was going to start off checking was the EGR valve.
Does your CEL come on during start up? (This is normal). Maybe the bulb is dead? lol
I'm just wondering because the symptoms you are describing are exactly what a bad coil pack would do.
well replacing all 6 coil packs isn't too expensive. The labor if I have the dealer do it is.
I may give that a try first. How many miles do coilpacks typically last? Considering I have 153K on my car now, there's a lot of things that cuold potentitally begin to fail IMO.
Could be a throttle position sensor too
Even still, buying a new TB for $200 as someone else found isn't too bad of a replacement part either for me.
With a scan tool you could test the TPS. If the reading is jumping all over the place while you are WOT and "surging" that might be a way to diagnosis it.
If you aren't getting misfires then it probably isn't the coil packs. Have you replaced the spark plugs yet?
Another member said to check the TPS sensor, but I don't know how else to check it. Should I just disconnect the harness from the TPS sensor and plug in a voltmeter and check it at idle and WOT?
Well...it's kinda fast...
I would check the spark plugs again just to be sure. I recently replaced mine and somehow one of the rear plugs backed out of it's seat. No CEL's, but my throttle response and fuel economy dropped significantly. I actually heard a weird noise which led me to check the plugs. The sound I was hearing was the compression blowing passed the loose plug. I used anti-seize and re-torqued the loose plug and now no noise and the throttle response and fuel economy are back where they should be. Just a suggestion, cuz I never would have realized it until I checked. I would have thought something like this would throw a CEL, which it did not.
^^^ I'll look into that after I check the EGR valve.
I looked in my Helm's manual but I haven't been able to locate where the EGR valve is. I want to try to clean it to see if that will fix the problem.
Anyone know where the EGR valve is? It's connected to the Intake Manifold as reported by the Helms manual, but it doesn't show where in the engine bay it is located.
may want to try to clean the IAC as well. That could cause symptoms like you described
Cleaning EGR ports
https://acurazine.com/forums/showpos...39&postcount=8
EGR
Cleaning EGR ports
EGR
^^^ thanks man!
I hope I will be able to remove the part and clean it without messing anything up.
As for my IAC valve, I had a new one put on earlier this year, so cleaning it at this point isn't needed.
Thanks for the info!
Alright, I went ahead and ordered a new EGR valve. I haven't had time to take the part off to see if it needs cleaning. And the new valve and gasket was only $80. So I'll just put a new one on and see if that remedy's the problem.
If it doesn't, next up to check are the coil packs, MAP sensor, TPS Sensor not in that order.
motor problem
TPS or MAP sensor would cause your car to jerk and stumble off idle as soon as you step on the gas and would prob cause a CEL.. You could stick a voltage meter inside the TPS to check for the correct voltage should be above 13volts(if im not mistaken) but your issue sounds like an EGR valve.
^^^ Thanks for the info. That's what I'll be trying IF the EGR valve replacement doesn't solve the problem.
Probably be at least a week and a half before I get the part. Picked it up from acuraoemparts.com and ships from Florida.
Originally Posted by kyle77777
Does the problem you have ever make your car die/shutoff? Or just sputter?
As for sputter, well it doesn't make that odd sound like it's not getting enough gas, what happens is during acceleration, typically in 2nd and 3rd gear and worse when going uphill, it doesn't accelerate smoothly, instead it surges/bucks.
Also many times during acceleration, especially uphill, if I were to go WOT, the car feels underpowered and slowly starts taking off, granted faster than I was accelerating before i went WOT, but definitly not the way it should behave typically at WOT.
Gonna cost to catch up
I had similar symptoms the first week I bought my CL, I had taken it to the dealership probably 5 times with no luck. Changed injectors, replaced coil packs etc. They ended up finding out what it was, and it was I had bent intake valves. I really hope this is not what is whats wrong with yours, cause it was a $4K job (warrantied).
They said it was caused from the previous owner probably accidentally missed a shift and red lined the RPM's at a high speed.
I hope to god that's not what it is!
I think I can count on one hand how many times I've taken it up past 6,500RPM. I do drive my car hard, but I know how to shift. Hell, my stock clutch lasted me till 150K miles.
I want to weed out all these small pesky items before I look at the big ones.
http://replacement.teamacuparts.com/...=null&dp=false
Description: EGR Valve. incl. gasket (see NOTE before ordering!!) Some vehicles may experience clogging of the intake manifold EGR port. For vehicles that exhibit this specific problem, the Honda dealer has extended the warranty on the EGR system to 8yrs/80K miles and will modify the EGR system and install a different EGR valve at no cost to the vehicle owner. Vehicles that do not experience clogging of the intake port are not subject to this extended warranty and should use the 18011-P8A-A00 (or 18011-RCA-A00) valve as usual. Contact your local dealer for more info.
I didn't order this one, but was just curious about what they are talking about, hence why I posted it.
I ordered the standard one Part # 18011-RCA-A00
Got my new EGR valve and gasket today. Tried to install it tonight but the engine was still too hot so I'll have to do it tomorrow.
I also have to pick up a wrench from Autozone to make it easier to get at the bolts that hold the valve.
More news tomorrow.
More news tomorrow.
Swapped out the EGR Valve this morning.
I had to pick up a 12mm angled wrench to get good access to the bolts. I suppose you could get to it with a normal wrench but with all the hoses and stuff it made it much much easier with the angled wrench.
Anyway, so I took detached the cable, removed the two bolts, and took off the old EGR valve. The openings on it looked alright, didn't seem dirty. The gasket was pretty much stuck on the valve, couldn't peel it off if I tried.
I placed the new gasket on the mount location for the gasket, placed the valve on the studs, reused the same bolts and that was it. Took a total of an hour to do. Definitely can be done in less time. I took it slow after I took the part off and took pics, looked at the part and stuff. You could honestly probably do the swap in 20 minutes. Very very easy to do.
In any case, I've noticed a few things immediately after swapping the part. Car is idling better, seems to be running smoother during acceleration as well. engine response is better too. For a high mileage car (150K+ mi), I'd recommend doing this replacement because it's such a quick and easy repair. Parts ran about $80 for the valve and gasket from acuraoemparts.com
As for solving all my issues though, well the delayed throttle response is still there. It's not as bad as it was since the car is running smoother, but too me it's still noticeable.
At idle I was checking the throttle response. The car would be idling at 750rpm. I'd slowly apply pressure to the accelerator and what would happen is, rather than the throttle inching up slowly, it would shoot up to 1250 or 1500rpm out of no where. There was no middle ground. I tried and tried, but I couldn't get the throttle to response slowly and accurately within that range for some reason. My guess is the TPS sensor is going bad. The throttle cables aren't sticking as far as I can tell.
So next up to replace is the Throttle Body, which I do have some questions about that I will post later.
As for the EGR valve replacement, I'm glad I did it because it did improve things. Definitely not a waste of money.
Something else I noticed that's improved on my car since swapping out the EGR valve, I no longer have that odd sputtering/surging feeling when accelerating from a stop or low speed on level ground or going uphill. It's completely gone.
Nope hasn't ever died on me or shutoff, although when I'm letting the clutch out, it sometimes feels like I have to let it out slower or give it more gas otherwise it'll stall. I know it's not a clutch issue because I just put in a new clutch earlier this year.
how many miles on the car and have you changed your PCV valve? should be done about every 45K miles on "most" cars.. if the PCV gets stuck closed you are killing the vaccum pressure in the motor, if it gets stuck open you have a leak and the motor will surge..
I just diagnosed and fixed the exact some symtoms on a buddies car over the weekend, he had terrible throttle response, and surging..
cleaned the TB, replaced the PCV and IAT and his motor was like new again.
cycdaniel
12-17-2019 10:58 AM
justin7779
12-25-2015 10:33 PM
sockr1
10-01-2015 01:31 AM
