What everyone up to?
#1122
idk why they have speed bumps the 5 that i have been to dont
#1126
#1134
i actually don't have my car right now. i just dropped it off at the transmission shop. my warranty company is sending out another person to check the tranny again, such a pita. when the transmission place called the warranty company yesterday, it sounded like they were going to cover everything, but needed to send someone out to verify everything.
#1141
you should try some rocky mountian oysters then
right where that vent tube would drain onto, but anyways if indeed it is that seal, not very hard to replace and not much labour to do it, so that is always good
it is between the left and middle case.
#1143
#1145
the leak is actually at the back, you have to look down the back of the engine bay to see the leak, its right under the cooler line
#1147
#1149
#1150
, that was more of a joke, but for trying such different foods, iron stomach
#1152
they are right before the camera, so that you slow down for the camera to take your picture, but even then cameras are fast enough today to take your picture at highway speeds, so yeah i don't know why they would have them , other then to slow people down
so can you get your car for the weekend then to run it (still should be driveable too, if not that bad, just sounds like it is weeping right now, so just carry a bottle of atf with you and the right tools to put it in, so you can run it this weekend)
anyways at least it is an easier fix, and should only be a couple of hundard $$$, and not thousands
#1156
