Key Won't Turn
Key Won't Turn
:surrender Ok, so I'm changing the ignition switch because once a month or so my 2000 TL won't start. Now the key won't turn. What did I do wrong? I looks like the immobilizer is keeping me from stealing my own car. Can you help me? :surrender
I'm your Huckleberry
Hopefully its not what happened to my wife's Pilot. She accidently put our Ford Explorer key in the ignition. It stuck a little but she pulled it back out. When she put the Honda key in, nothing happened. When I got there I realized the immobilizer had activated, but apparently several of the pins in the ignition lock were damaged and they had to put it on a roll-back and take it to the dealer.
It cost us roughly $250 to have fixed.
Check your key first, see if there's anything wrong with it. I had trouble turning my key when i noticed it was slightly bent. like a tiny little bit.
Or try using your second set of key to see if it turns properly.
Hope this helps!
Hope this helps!
you're right, the steering wheel was in a position that put preasure on the key. when I moved the steering wheel then the key turned fine. time for reassembly. thanks!!!!
rockyboy
08-04-2024 10:35 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
