DIY for APP Sensor?
DIY for APP Sensor?
Where should I pick up the part (read cheapest place
) and is there a DIY for it?
It seems like it should be easy but just like to do my research first.
I had a limp mode and it through a code relating to it, and it just went into limp mode again today on the wifey. A quick pull over, turn off, and turn back on cleared the issue, but left the check engine, but i want to get it taken care of.
Thanks to anyone that can help.
King_Solomon_357 (04-13-2013)
and to add to this.. where the heck it it? LOL
i figured it would be down by the pedal but it seems as though it goes through the firewall... so where is it and how do you access it? top of the engine bay or under the car?
Pull the plastic covers from between the strut brace and the firewall (they snap out like the other engine compartment covers.) You'll see the cable running along the firewall to an assembly on the passenger side firewall. It has a plastic cover with two 10mm bolts. Remove those and then you should see a couple more bolts holding the bracket to the strut brace and the firewall. Remove those and then work the cable off of the assembly. The new sensor doesn't come with the complete bracket, so you'll have to swap a few parts over. I found the cheapest place to order was from AcuraOEMparts.com @ ~$120. Enter your model info and search the entire list. It is listed as the "accelerator sensor". Yes, I've been looking too.
The following 2 users liked this post by NE14RoxCJ:
musicosolo (06-11-2012),
Pankul (10-14-2012)
OK, I got my new APP sensor today and the install was as easy as I expected. The only difficulty was with the bracket. I couldn't get the whole assembly out between the firewall and the strut brace. No big deal, though. Only two bolts hold the sensor to the bracket. Turn the bracket over after removing the bolts that hold it on. Then remove the two bolts holding the sensor on and the pieces will come out individually.
![Name: IMG_1729.jpg
Size: 147.3 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/54585d1501300241-diy-app-sensor-img_1729.jpg)
This is the sensor before and after replacement.
![Name: IMG_1727.jpg
Size: 161.3 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/54586d1501300241-diy-app-sensor-img_1727.jpg)
Flip the sensor assembly over and remove the two 10mm bolts (the recessed ones) that hold the sensor to the bracket.
![Name: IMG_1725.jpg
Size: 152.8 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/54587d1501300241-diy-app-sensor-img_1725.jpg)
Loosen the nut holding the cable to the APP sensor. I adjusted the jam nut after I installed mine, so I wasn't worried about where the nuts were.
![Name: IMG_1724.jpg
Size: 161.2 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/54588d1501300241-diy-app-sensor-img_1724.jpg)
And this is the bracket after removal. Just set it aside after removing the sensor from it.
Place the bracket back behind the strut brace and bolt the sensor back on. Then bolt the whole assembly to the brace and firewall. I adjusted the slack out of the cable and tightened the jam nut.
See my other post for results.
BTW, I've got a few more miles on my new APP sensor and am proud to say the car is driving great. I never got a fault from mine because it would never "fail". For such a smart vehicle, I'm not impressed. But, I still love my car. And even more since I changed that sensor. Just wish it would have TOLD me what was wrong instead of me having to take a shot in the dark.
Im tempted to try this, my car hesistates really bad only when taking off and it doesnt do it every time i take off.. but in the most inconvienient times like when pulling out in fast traffic or crossing a mediun or something... it feels like it just drops down into a lower gear and looses power... doesnt jump and the rpms dont jump high... lol it goes like this
----__---___----
----__---___----
And a few more weeks since i checked this thread. Sorry bout that. The car is smooth and steady at cruise. The APP sensor was definitely causing that surging. BUT I still have that hesitation when accelerating. It's more noticable when accelerating hard, but not hard enough to make it downshift. Like pulling out of a tight curve still in 3rd gear and easing into the gas to just before it downshifts into 2nd. Like MWayne said ---__---__---. It feels like that. Driving normally, it feels a little sluggish at times, but not so bad. I'll start looking into that soon. I need to do the TB water bypass and see if that helps. It seems like a timing issue and I wonder if it is just because it's so damn hot. 100F is nothing around here. I've been seeing more like 104-107 on my little weather station at home. I bet the car is sucking in a bit hotter air than that.
https://acurazine.com/forums/showthr...=597082&page=4
so far i have read the possible culprits can be a faulty:
Throttle position sensor
App sensor
IAT sensor and
Knock sensor ( so far this replacement cured one member of his problems)
did you fix yours yet or no.... ive heard about the knock sensor too and thinking to give it one more last chance if not i will be done with acura pretty soon...
Buka, I'm def. not to that point. I haven't fixed the acceleration problem, but it's not bad enough to make me swear off Acuras. I DID fix the problem that was giving me such a headache. The APP sensor was causing the throttle to be VERY erratic at cruise. It was really irritating. The acceleration problem is not that big of a deal since I'm not trying to race people all the time. If I were, I wouldn't have bought such a big car in the first place.
I've got the same issue on my 05' 6sp.... It feels like I'm taking off in 2nd gear sometimes and other times it flat out flies. After reading up on this stuff it seems like it might be the knock sensor but I'm NOT happy. It seems the more "technologically advanced" cars get, the more shit breaks. Let me know how you make out with the knock sensor.... I think that's probably my next route.
This tutorial was great! I just finished changing my APP sensor like half an hour ago cuz my TL always went into "limp" mode. Some threads said it only takes like 15 min but today was like the hottest day in MA has ever had and i burned myself like a bunch of time so i took me almost 30 min but now the driving improved noticeably. I guess i'll have to wait and see if this really solved the issue though. Once again thanks for the walk-through
Hi Everyone, THX for the post. My 04 TL was occasionally going into the "limp" mode. I would have to pull over in the middle of a freeway. My oil change guy finally pulled the codes and acurazine helped me to confirm that it was a APP Sensor problem. After following this thread, I replaced (DIY) this sensor and my limping problem is 100% gone.
THX!!!
THX!!!
OK guys, so my car apparently went into "limp" mode yesterday for the first time. One member on here told me it is the app sensor, but the guy who sold it to me said he replaced the throttle body sensor not too long ago. When I have the code pulled, will it tell me which part I need, or am I going to have to guess?
How much is each sensor, and where should I buy them?
p.s. not thrilled about this because I just bought my car last month.
Also, how often will this limp mode occur if I don't replace anything?
And yes, the code will help make a determination.
sorry, meant tp sensor... and I just got the code pulled and it said tp/ap sensor, so since the previous owner put a new tp sensor on, I'm assuming I need a new ap sensor... advance auto sells one for $280... where can I find the best price?
What was the exact code #?
$280 is way too much for an APP sensor. But need the code # first to know for sure it's the APP sensor
so what does that mean?
There are multiple codes for both, that's why you need the code #.
Even though the CEL is off, the code should be stored in the computer and you may be able to pull it. You can find the app sensor for $125 online. I replaced mine two weeks ago and it took about an hour
my question is: if the previous owner replaced the throttle position sensor, but the code I pulled said "throttle position sensor/acceleration pedal sensor", then should I just change the ap sensor? and if that doesn't work, do I have to replace the entire throttle body? if so, how much will that run me? and is there a DIY for it?
Chapter Leader (Arkansas)
I must share this with you guys. For the last 13 months, I've been experiencing issues with RPM fluctuations, hesitation, and surging. I live in Arkansas and the problems/issues seemed to present themselves more when it was warmer. While the issues were still slightly present in the winter, the spring and summer was awful. I have spent the last 13 months going back and forth with the dealer trying to figure out what the issue was. The dealership did a lot of work, including replacing my entire fuel system, but could never really isolate the issue. I read several threads on Acurazine and the issues described by others were exactly what I've been experiencing. I knew it wasn't a tranny issue. I ordered the part this past Sunday and it arrived yesterday. I must say that I am NOT mechanically inclined, but after pulling the instructions provided, it took me 27 minutes to change this part out. I drove it last night and this morning...the problems are 100% gone. If you could only imagine the frustration of 13 months...only to find out it was a simple $200 part that took less than 30 minutes to fix. Thank you...I LOVE Acurazine.
I replaced the APP sensor for the 05 TL, aftermarket product BWD #PPS1046. My son and I just got back from the Acurazine National Meet in KC. The trip, including cruising, was right at 800 miles. I will report that the issues are 100% gone. No hesitations, no RPM fluctuations...nothing. For $235 and a 27 minute repair job, I'm quite pleased.
A few reasons: 1) the part was cheaper than what Acura quoted me (I didn't feel the need to go OEM on this particular part). 2) I was putting the part on myself and didn't want to drive 2 hrs roundtrip to the dealer to pick it up. 3) I was crunched for time to get the part before driving to KC for the AZine meet (I didn't want to deal with the frustrations of the part for that long of a drive) so I ordered it locally and they had it overnight.
http://www.oreillyauto.com/site/c/de...2183&ppt=C0033
Even if you go with a different vendor (OEM, etc.), the part will look identical...so at least you can print it off and have it for reference. 'Just trying to help.
