Another vibration thread..
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
Alright, need some expert help/advise here
, I searched the forum regarding this issue but most are incomplete and the OP never found the fix..
So I have this vibration that occurs when I accelerate from a complete stop. It happens around 1.5-2k rpm @ about 40-50mph and goes away after. The strange thing is that this problem doesnt happen during cold morning drives. It seems to happen once things start to warm up. The vibration can also be felt in the seats,floor and can be seen in the rear view mirror.
The alignment shop did a free complimentary vehicle inspection when I brought the car in for alignment and said the cv axles looks in good shape. I have also checked for play etc and they seem to be fine..
What could be causing this??
Notes:
+ The car is lowered ~ 1.7-2in give or take.
+ Put on brand new rims and tires 3 weeks ago. Wheels were balanced using a Hunter GSP9700 assuming it was road force balanced. ( have hubcentric rings installed )
+ Alignment done the following week after and is set to factory specs.
+ Had raxles installed for about a year now. Guessing i have about 9-10k miles on them now.
This weekend im linking up with Aaron ( Sharksbeath ) to change the front + rear motor mounts and as well as 3 transmission mounts in hopes to put an end to this ( and thumping sound when going from P-R). If that doesnt fix it, could it just be a case of bad tires? (separating . out of round?? ) possible axles giving out?? Anything we should inspect while the car is off the ground??
Car: 05 TL AT - 87k Miles
Notes:
3G TL/2G MDX Owner
i'm assuming that the vibration was there BEFORE you put the new set up on your car??
only other thought on the vibration...LCA compliance bushings? axles can cause this (inner CV joint wear) which cannot be seen on visual inspection.
i'd say replace the motor mounts that you plan on doing, then reassess. if it's still there...then it could be the other two items i listed above. are you running spacers? your suspension set up can place excessive stress on the axles esp with spacers.
just throwing some stuff out there. say hi to sharkie for me!
TWiSDiT (04-02-2013)
flip the wheels around and see if there is any change
- The vibration was not there before I installed the new tires+wheel. However, I did mess around with the height and lowered it about 1/2in more than what it was prior.
- I hope the axles arent starting to go out.. i just replaced them
- No spacers
Also to mention, the vibration is even more definite when going up an incline at slow speeds.
update:
so with the help of Aaron, he was able to get the front motor and top trans mount out and replaced. ( pics of the upper trans mount not pictured ). Both were cracked :
![](http://i46.tinypic.com/vsnz1c.jpg)
Vibrations in P + low rev's seems to have eliminated but however, there's still a hint of vibration during acceleration up an incline at low rpm ( less defined compared to before ). We didnt get to finish the rear motor mount and the lower trans mount yesterday because we ran out of time.
3 2 GONE
122000km. What ever that is in miles. Still on the factory waffles. Lowered Just under 2 fingers in the front and just over 2 fingers in the rear.
You lower then this?:
![](http://i43.photobucket.com/albums/e353/kevontobyspics/IMG_0192_zps56a01ed5.jpg)
Pressure switches and new DexIII fluid should solve it.
2 fingers. Really? You can't measure it? 2 of who's fingers? A child's? An obese 40yr old mans? Chicken fingers?
The following 2 users liked this post by HG88:
paperboy42190 (04-30-2013),
Undying Dreams (04-09-2013)
I'm having a similar problem. Let us know what happens.
and yes I registered just to say this.
Im going to be busy this weekend so I wont be updating this situation until April 20-21
3G TL/2G MDX Owner
so i understand from your first post andy, the vibration occurs under acceleration from a stop and lower RPMs from 40-50 mph?
it could very well be your axles if you've switched out everything else that was worn or cracked. and from what i have seen prices on OEM axles have sky rocketed for AT.
do you have camber kits installed?
![what](https://acurazine.com/forums/images/smilies/what.gif)
yeah
correct, more like 30-40mph. yeah we looking at $1000 for a pair
and yes, i have front and rear camber kits. Alignments are set to OEM specs
if this is the case... looks like this the last year i will be low
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
3G TL/2G MDX Owner
i never really thought about that part but is there a way you can tell if its bad? just looked up prices and its gonna cost about $400 for a pair brand new oem ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
i have no vibration in the steering wheel. everything is good besides that little vibration i get at low speeds.. once cruising.. everything is fine lol i have high patience. If i have to spend more money on this car then i think its time for quits and return back to stock ( which i believe will cure everything ) ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
when my axles were wearing (aside from the clicking outer CV), i had a vibration in my steering wheel (more like a stutter of sorts) and subtle vibration through the floor and seats accelerating from maybe 10-15 mph to 30-40mph. if you mashed on it you could feel it more (which is what the shop foreman at the dealer did and he felt the vibration, as i sat in the passenger seat getting whiplash
). since my axles were replaced, all has been well. it's probably the one time you wished you owned a MT huh? unbelieveable the OEM pricing for the axles right now.![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
The intermediate shaft doesn't come in a pair... It is a one piece that connects to the tranny and the other side connects to the passenger axle...brand new its like 250.... I had a vibration issue and that solved it
im having this same problem except i get it around the 55-62 mph range. I dont hear any clicking so maybe not the intermediete shaft. My car is slammed and the acura tech said maybe i need to raise her up but i still havent tried that.... because my car looks so badass where she is haha but this is a helpful thread so keep it going!
I honestly can put money that the ride height is the issue. Im just testing out my luck to see if the mounts have anything to do with it since 2 were toast and I can only imagine the others left im going to replace.
Cruiser
I have had this problem for a long time now...no mods...inspection didn't turn up anything when I first had it inspected....first I thought it was the new tires I purchased at the time but they were road forced balanced....never could figure out the problem...maybe I'll have the dealer check it out again
Check your LCA/Compliance bushings. Chances are, they're destroyed.
lmao! thats the same reason for me man. It just wont look right.. I want to run this setup one last time this season at least. In the end.. gotta be function>form ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Oh and a quick question does lowering a car have an effect on the motor mounts and tranny mounts? my dad swears they do but i dont believe him, now the bushings i understand but the mounts?
I checked them before and they looked fine. maybe ill check them again.. the boots still look good with no rips.
yeah buddy, cant always take someones word for granted. Sometimes gotta see proof as well ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
no, i dont think so because motor and tranny mounts go bad from age.
Turns out all my motor mounts are done..... and the Acura Tech said they were fine... He told me he owned an NSX... i believed him from that point on. Moral of the story just cause the dude has worked somewhere for 15 years and has a super di duper rare clean car from your perspective car company there is no reason to believe him. Im getting my motor mounts and tranny fluid changed in the next couple weeks that should fix the problem right up, which means i can stay slammed
hell yeah! Ill go ahead and check the bushings at the same time to make sure those arent doing some metal grinding![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
A simple and cheap way to dampen this vibration is to pack the CV joints with new grease.
The grease inside the joint starts to lose its ability to perform its task. If you take the cup off from the boot you can remove the old grease and pack it with new axle grease. I guarantee if your vibration is only at low end it will go away after you reinstall the newly grease axles. I would also recommend replacing the boots when you do this if they are cracked. All can be done in about 2 hours and for less than $40.00.
oh heres a little update.. still havent gone about the other mounts yet. However.. I was messing with the damper for the front and set it closer to full stiff and it helped a lot ( i was at middle settings before ).. it really toned down the vibrations to the point its kind of enjoyable to drive once again. Theres still a hint left but its something i can live with, though i prefer to have none..
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
