j32a2 swap in to base 2002 tl
I have a 2002 base tl and im planing on swapping out my blown j32a1 motor for a j32a2 type s motor. Can anybody tell me if I can use the base tl wiring harness on the type s motor?Also what else would I have to change besides motor ,tranny and ECU?Please help
wham bam thank you ma'am
just search. easiest thing to do is try to find a wrecked tl/cl front clip at a junk yard. that way u have everything u need plus some. but the most important parts u need
type s engine, engine bay harness, dash harness (i thing so), ecu, 5spd trans if u have the 4spd auto, vsa, and the rest depends on what the engine comes with.
B A N N E D
Your Garage
Acura's Vehicle Stability Assist (VSA) system. VSA adds side-slip control to the standard car's ABS and traction-control mechanisms and steps in to help out when drivers venture beyond the car's normal capabilities.
so to recap, all i needed was engine harness, ecu, gauge cluster (this one is a maybe as well but they look nicer)
plug and play type s ftw
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
i went without VSA
its an extra throttle body infront of the regular one, i didnt go about finding what i needed to make it work. the only thing you'll have is an annoying light on your gauge cluster
plug and play type s ftw![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
And can i give you a tip...... Pull out the light bulb in the VSA spot
Are you kidding me.. the TCS in the TL is the biggest waste of weight in the car and hinders traction more than it helps. If you live n a snow climate you should be running snow tires (especially in Colorado)
B A N N E D
and as said i would love a LSD for the auto, but no one gets one, so we only got TCS/VSA, which is still going to be better then nothing
also for snow tires here, not really needed
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
SS brakelines does wounder for it too, with faster response times
(especially if you stay in metro Denver a lot), but now if you live up in the mountains, or go up there often (skiing/snowboarding), that is a whole different topic
B A N N E D
I dont live in the mountains either, If there is a chance fore more than 1 or 2 inches of snow on the road snow tires should be used (i wish it were actually a law that they were mandatory like in some places in europe) Either way i would get stuck easier with TCS than without it. I also found it pointless to only go up to 20 mph.
also the other thing is that down here, the snow is normally melted off the roads the next day (mainly the plowed roads, not back streets, but even then the back streets melt quite fast as long as they are not shaded)
and i think even having just good all seasons tires on every car would help reduce accidents and such, hell you can go through "emissions" with bald tires if you wanted, even during the winter,(i've gone through emissions before with a bad master cylinder, so hardly any brakes, it went out like a mile or two before i got to the test center, but it did get fixed right after though)
other then that we have no state inspections here, and for the emissions, all they are really worried about are the pollutants/emissions, nothing else
we also don't get as much snow as you think as we do in metro Denver, you are probably thinking of the mountains more so, which get a lot more then us down here (so the reason for a whole different topic thing)
Very good read.
http://www.caranddriver.com/features...mparison_tests
B A N N E D
And this is the misconception people have about snow tires. Snow tires aren't so much about how much snow you can go thru, But Its the Braking and cornering that is most important. We have the same road conditions here. Roads are usually cleared same day or next. But its the DURING that people need the tires. All seasons can not hold a candle compared to dedicated snows.
Very good read.
Very good read.
also people already have enough complainants about the tire noise on all seasons, so try winter tires then
![what](https://acurazine.com/forums/images/smilies/what.gif)
also studs are horrible for the roads themselves, and we already got shitty enough roads here (and thin when compared to say Utah's, you can actually hear a difference from the tire drown/noise when you cross state borders [ours roads are much higher pitched for noise wise)
and you should see the state highway that i drive on to work everyday, some massive tires ruts, hard to tell, but i would say a good 1" or so deep, and this is not some highway in the boonies either, it's 4 lanes total, with it being the main highway into town from denver (basically if you are coming anywhere from near denver you travel on that highway)
