Bye Bye EGR......
Old Jun 2, 2009 | 09:04 PM
NVA-AV6's Avatar
BANNED
Bye Bye EGR......
Well, not exactly, but damn close enough. As we all know the EGR system robs some power by injesting hot/dirty exhaust gases directly back into the intake. We can't remove the valve without throwing a code and we can't block it without throwing a code. If we block it the ECU throws a "Isufficent Flow" code as well as the ODB emissions monitor will show error since the ECU actually detects the lean out caused by the EGR opening and flowing exhaust back, and this is the key, the ECU does not care weather it is hot exhaust or cold/clean intake air. So I decedied to machine out a EGR Bypass Adaptor that allows us to connect eaither a breather filter or a hose connected back to the breather fitting on the intake. I just came back from a 50+ mile test drive with no codes thrown and for good mesure before I left on the drive I reset my ECU and emmissions monitors after the drive I checked and the EGR emissions monitor was happy with the bypass, so this will not effect passing emissions, and probably will pass visual if you hook a hose back into the intake.
Thanks to Shonda for jogging my brain and getting me to think of this.........
This will also work for all J series engines......
Old Jun 2, 2009 | 09:16 PM
Timeless's Avatar
That simple and pretty awesome. It seems like there are still thinkers out there.
Old Jun 2, 2009 | 09:38 PM
phee's Avatar
I got the Shifts
got a pic of just the adaptor?
Old Jun 2, 2009 | 09:54 PM
surlynkid's Avatar
Too many $$ toys
very nice.
Old Jun 2, 2009 | 09:57 PM
JwongTLS's Avatar
Whats the point of it?
Old Jun 2, 2009 | 10:02 PM
TL|GTX's Avatar
A Black TL
haa that looks cute
Old Jun 2, 2009 | 10:08 PM
phee's Avatar
I got the Shifts
Originally Posted by TL|GTX
haa that looks cute
:ghey:
Old Jun 2, 2009 | 10:17 PM
Bearcat94's Avatar
AZ Community Team
Cooler air.
https://acurazine.com/forums/showpos...95&postcount=1
Old Jun 2, 2009 | 10:57 PM
Dave_B's Avatar
FYI, EGR valves are closed under WOT situations which means they're not robbing power. Late model EGRs, like the one found on the TL, are vacuum actuated and controlled by a solenoid via the ECU During full throttle, there is no engine vacuum therefore no EGR.
One thing that could possibly happen by disconnecting the EGR is you may experience moderate to severe detonation under heavy loads (ie going up steady grades in low/midrange rpms). The exhaust circulated into the combustion chamber actually helps control combustion chamber temps which reduces the need for higher octane fuels. Hopefully the knock sensor(s) on the J series are quick reacting and will stop the detonation before it becomes dangerous.
Old Jun 2, 2009 | 11:21 PM
timmahh's Avatar
it's me, Alan Rickman.
Dude.. Get a new radiator hose asap.
Originally Posted by NVA-AV6
Old Jun 3, 2009 | 12:33 AM
Tumbleweed13's Avatar
Sorry but by doing this all you have done is raise your combustion temperatures, shorten the life span of your engine and cause it to now fail a smog test for high NOx emissions.
Old Jun 3, 2009 | 01:56 PM
TL|GTX's Avatar
A Black TL
lmao hopefully this wont be a complete failure
Old Jun 3, 2009 | 02:18 PM
Majofo's Avatar
Old Jun 3, 2009 | 02:29 PM
CleanCL's Avatar
Just to add my 2 cents:
EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. Intermixing the incoming air with recirculated exhaust gas dilutes the mix with inert gas, lowering the adiabatic flame temperature and (in diesel engines) reducing the amount of excess oxygen. The exhaust gas also increases the specific heat capacity of the mix lowering the peak combustion temperature. Because NOx formation progresses much faster at high temperatures, EGR serves to limit the generation of NOx. NOx is primarily formed when a mix of nitrogen and oxygen is subjected to high temperatures.
At WOT, the EGR is not in use. The only way this would benefit your car is in partial throttle, but also only if the car is tuned properly. If you delete the EGR and the ECU believe it is functioning, it is functioning under the belief that the cylinder temperatures are lower. Once you remove the EGR, the temperatures actually will rise in the cylinders and the ECU will not adjust to add more fuel and detonation can occur.
If I was doing a custom tune of my car, I would gladly remove the EGR as I would be able to compensate with fuel during partial throttle. But on the stock ECU... not sure yet.
Old Jun 3, 2009 | 02:44 PM
Trew's Avatar
You have also decreased your gas mileage by doiing this mod.
Old Jun 6, 2009 | 02:54 PM
I hate cars's Avatar
Agreed. And there's always a timing bump in the maps to make up for the lost power when EGR is functioning. This is where it will really ping with no EGR.
I don't have it on my GN but when I had the stock ECM I had a chip burned especially for this with lower timing. It did try and ping at part throttle before the "no EGR chip" which is especially weird on an 8:1 engine. I only did it because when I ported my intake manifold I removed the EGR riser to get more volume out of the plenum.
I have to say this is not a good mod unless you can back off the timing to compensate but then you're back at square one power wise. The extra heat generated by the EGR in the intake manifold is likely not measurable.
If I did this mod it would be for the cleanliness of the intake tract over the course of a few hundred thousand miles.
Old Jun 6, 2009 | 02:55 PM
To the OP, that is a cool trick to fool the ECU into thinking it's flowing.
Old Jun 10, 2009 | 12:11 AM
mar8cin's Avatar
nice looks good
Old Jun 11, 2009 | 09:44 AM
XxAfG786xX's Avatar
looks good....let us know how it performs
Old Jun 11, 2009 | 10:51 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
interesting...
Old Jun 11, 2009 | 11:11 AM
NVA-AV6's Avatar
BANNED
So far, so good, emissions monitor is happy, no changes in timing according to my scanner and no detectable changes in gas milage.
Old Jun 11, 2009 | 11:15 AM
timmahh's Avatar
Ehh.. it sounds like absolutely nothing has changed other than your car might be polluting a bit now.. so what's the point of doing this?
Acura604
Oct 7, 2015 06:08 PM
gavriil
Jan 1, 2004 12:30 PM
kfox88
Jul 8, 2002 10:40 AM
