blown engine problem
Well looks like I will not have a car for a while. I blew a rod right through the oil pan. I would love to get some help to know what my options are. Does anyone know a reputable junk yard or place I can get an engine from, or how much they cost new? I would love a 3.6L rebuild as well, does anyone know a place that can fix my engine to be rebuilt and stronger. I know this cost more money to do, but in the long run it would last. I live in NJ
It was the s/c. I had it installed since OCT, no problems and never beat on car. All scheduled mantience's were done as well. One good run keeping up with a 12.5 second s4 and BOOM, engine shut off and rod went through oil pan. I did beat on it for that one run, I would recommend anyone going S/C get AEM FI/C or a good tune. Apparently the ACM which everyone knocks and doesn't tell us why it is garbage, just remaps fuel but doesn't actually "tune" the car. I learned the hard way, but I am looking into a 3.6 rebuild and going N/A or putting s/c back on and being in the 375-400WHP range.
"Like None Other"
damn....did you have any wideband sensors/gages hooked up? sounds like the SC caused this. sucks to hear this bro. possible lean condition?
i had to replace my engine due to a non-related issue and got it for $500 wit 40k on it. i got lucky but check around at some used junkyards or on some forums for a used j32a3 engine and build it up with lower compression pistons and wateva else you desire. really sorry to hear this as it wont be cheap. g' luck with everything and keep us updated.
Thanks for the honesty AckTL05
Did you have your methanol kit spraying at the time the rod broke? If yes, what percentage meth/water mix was it? The reason that I ask is because I would hope that a strong mixture of meth would had prevented the denotation.
Chapter Leader (NY/NJ)
Damn. sorry to hear that. i am currently replacing my motor right now too but warranty is covering everything. if they weren't i would've went with the build too. GL on everything.
Billu99tl
09-13-2015 11:30 AM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
