NY/NJ New Jersey & New York
'07 mirror mod on '04 TL help!
Old Aug 22, 2011 | 09:52 PM
Elg0rd0yadigg's Avatar
so quick background guys i have an 04 tl and i put 07 mirrors on it and i unfortunately took it a backyard mechanic, who only wired them up to blink.
now my problem is that my memory seats dont work and i dont have power to my mirrors so if i want to re-position them i have to manually push the mirrors themselves.
at first i didnt complain to the guy cuz i took to him without doing research, and he told me that it would work do to the wiring harness being different, but then i found i searched the 07mirror mod thread and found others with 04s and no issues...
so basically i need either a good spot in new york that can fix them and wire them correctly or an answer to this question....i was told if i just get an entire 07 mirror wiring harness and take it to a shop if they wire it up that way it solve my issue?
thanks for any helpful advice in advance...
Old Aug 23, 2011 | 03:32 AM
charleymutton's Avatar
Check a blown fuse underdash left side kick panel right above where u open the latch to the hood .. Am not sure the fuse number but am thinking it should say power mirrors or power seat .. I know the TL had a problem with washers/power mirrors and seats not working .. And you had to upgrade the fuse to a higher amp .. Check that before u go crazy with the wire harness
Old Aug 24, 2011 | 12:46 AM
thanks will do!!!........bumpppp any other advice out there????
Old Aug 24, 2011 | 10:18 PM
UA6's Avatar
UA6
Try to look for members that live in your area and ask which shop they go to for their work. I'm sure someone could recommend a good place to go to. Look in the regions sections and find someone that live in NY.
Old Aug 25, 2011 | 08:43 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
NO NO NO NO NO NO NO NO NO NO!!!!!!!!
op, Im in yonkers. PM when you ready to link up.
Old Aug 25, 2011 | 08:54 AM
What else do you want them to do besides blink?? thats all they do from factory. You dont need a wire harness. And Always come to Acurazine where we have probably done it all already and have a DIY for it so you wont get screwed.
PM your info and we'll talk from there.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
