Tarnsmission and Brakes Help!!!
Old Aug 22, 2014 | 05:14 PM
mimi_s11's Avatar
I drive an automatic 2004 rsx. Yesterday I took it to Jiffy Lube to get the oil changed as well as the tarnsmission fluid exchange and powersteering fluid exchange. As soon as I got my car back it was not running right at all. The gears were not changing, I was only driving 20mph at it was 3000+ revs. The brakes were locked up, I could not hit the brake pedal at all and the car would completley stop even if it was on neutral. I took it back to the jiffy lube and they said they had no idea what was wrong with it, after about 20 minutes of playing with it, it magically worked again. They did not have a mechanic to take a look at it so they told me to go in today but I had to work so I did not get a chance. Point it this morning the car is having the same issues. I heard it might be an issue with the air in the transmission fluid. Does anyone have any idea what happened and what it will take to fix the issue?
Old Aug 22, 2014 | 05:21 PM
1black_seven's Avatar
Slot Machine Lubricator
So they drained and refilled the tranny? Did they use the right fluid?
They didn't do a flush did they? I've heared acuras aren't supposed to be flushed.
Old Aug 22, 2014 | 05:53 PM
mimi_s11's Avatar
I think the drained and filled it agian but I am not sure if they did a flush. What would happen if they did do a flush?
Old Aug 25, 2014 | 11:48 AM
Possible failure. Acura warns against it.
Old Apr 22, 2016 | 03:32 PM
jamescallowa's Avatar
9th Gear
Acura recommends using genuine Honda / Acura transmission fluid otherwise any other fluid would ruin the transmission as most fluids don't have high viscosity like Honda transmission fluid does.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
