Light Bulb Replacement... need info plz
Mike D from Ohio
My dad has a 2001 RSX and after seeing the bulb swaps I did on my TSX, he wants some of his own bulbs replaced.
1.) What kind of LED bulbs does the RSX take for map and dome lights?
I'm guessing they are 3022 festoon base (30mm or 31mm)
Please confirm or correct me.
2.) What is the bulb code for the reverse lights?
I'm guessing they are 7440.
Again, please confirm or correct me.
Lastly, has anyone tried the 194/168 wedge base high-powered LED TOWERS in the trunk/cargo area? If so, I was just trying to see if they fit. I know the base fits since its a 194/168, but sometimes the bulbs' bodies are too big for the lens casing.
http://www.sylvania.com/ConsumerProd...lacementGuide/
best website for all of you bulb needs use the replacement guide to find the bulbs you need this should answer you questions
Originally Posted by Sylvania Website
2002 ACURA RSX
Low beam headlamp
H1-55W
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen - The Brighter Light
High beam headlamp
H1-55W
Parking light
2827
Front turn signal
7440
Rear turn signal
7440
Tail light
7443
Stop light
7443
High mount stop light
7440
Fog/Driving light
H11-55W
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7440
Front sidemarker
2827
Rear sidemarker
168
Map light
DE3175
Dome light
DE3175
Trunk/Cargo area
168
Low beam headlamp
H1-55W
High beam headlamp
H1-55W
Parking light
2827
Front turn signal
7440
Rear turn signal
7440
Tail light
7443
Stop light
7443
7440
Fog/Driving light
H11-55W
License plate
168
Back up light
7440
Front sidemarker
2827
Rear sidemarker
168
Map light
DE3175
Dome light
DE3175
Trunk/Cargo area
168
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
