Headlight bulb change gone wrong
Old May 25, 2016 | 06:21 AM
romac's Avatar
5th Gear
I broke the clip holding the bulb in place. The rubber gasket was a bit baked in place and I tugged apparently a little too much, broken plastic wire clip holder... bam. Now what? Any ideas? btw, zxe bulbs went simultaneously, one year.
Old May 25, 2016 | 09:05 AM
buy a new one
Old May 28, 2016 | 10:12 AM
romac's Avatar
5th Gear
brilliant, thanks.
Old May 29, 2016 | 10:39 PM
knavekid's Avatar
Acura Fanboy
If you can find the broken piece, you should be able to JB Weld it back on. Perhaps you can rig up another way to fix it. Either way requires removal of the bumper cover in order to remove the headlight assembly.
Old Jun 1, 2016 | 02:35 PM
romac's Avatar
5th Gear
Thanks, the tiny plastic curl that holds the clip has broken. I just used the rubber collar cover to hold the bulb in place. It will probably shake at speed over bumps but oh well. It is functional so far.
I CU2
Feb 12, 2016 11:45 PM
Skirmich
1/2G MDX (2001-2013)
28
Feb 8, 2016 03:38 PM
