Is this the CORRECT Engine mount I need?
Old Nov 5, 2013 | 11:26 AM
ixSLACKERxi's Avatar
Hey guys, I have to order a front Engine mount for my 2004 Acura RSX Type-S.
Money is very tight and I need my mount replaced because it's broken and I can't pass inspection without it. I just want to be sure I am getting a mount that will fit my car. The link is below, is it the correct one?
http://www.ebay.com/itm/2002-2006-Honda-Civic-Acura-RSX-Front-Engine-Motor-Mount-4549-/390548204948?_trksid=p2054897.l4275#rpdCntId
Old Dec 7, 2013 | 12:42 AM
UA7meow's Avatar
8th Gear
You should look into buying Energy Suspension engine mount inserts, its pretty affordable. They make it for the front and rear mounts. Its not a full mount they just insert into your factory mounts but will reduce engine movement and also wheel hop. there is a negative side affect, you will feel the vibration from the engine and may have dashboard noise from the vibration.
Old Dec 18, 2013 | 09:50 AM
BattleofXs's Avatar
if the mount is broken, adding inserts isn't going to help, that's a horrible idea.
go to the junkyard or clubrsx.com and find a used mount, then maybe add the inserts for additional longevity
Old Mar 30, 2014 | 03:19 PM
thanks guys but it turns out the A hole who inspected my car and told me my mount was broken is either an idiot or just assumed I would let me replace the whole damn thing. I took it to a closer mechanic for inspection so he would tell me which mount and how much and he said it's not broken only needs a bolt, so he fixed that and fixed a leak in my exhaust for like $40.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
