Is this the CORRECT Engine mount I need?
Hey guys, I have to order a front Engine mount for my 2004 Acura RSX Type-S.
Money is very tight and I need my mount replaced because it's broken and I can't pass inspection without it. I just want to be sure I am getting a mount that will fit my car. The link is below, is it the correct one?
http://www.ebay.com/itm/2002-2006-Honda-Civic-Acura-RSX-Front-Engine-Motor-Mount-4549-/390548204948?_trksid=p2054897.l4275#rpdCntId
You should look into buying Energy Suspension engine mount inserts, its pretty affordable. They make it for the front and rear mounts. Its not a full mount they just insert into your factory mounts but will reduce engine movement and also wheel hop. there is a negative side affect, you will feel the vibration from the engine and may have dashboard noise from the vibration.
thanks guys but it turns out the A hole who inspected my car and told me my mount was broken is either an idiot or just assumed I would let me replace the whole damn thing. I took it to a closer mechanic for inspection so he would tell me which mount and how much and he said it's not broken only needs a bolt, so he fixed that and fixed a leak in my exhaust for like $40.
sockr1
10-01-2015 01:31 AM
