Integra 2023 Acura Integra Technical Service Bulletins
Old May 20, 2022 | 07:02 AM
EE4Life's Avatar
Forum Contributor
2023 Acura Integra Technical Service Bulletins:
TSB 22-015 - 2023 Integra: TQI Information and New Model Information
Applies To: 2023 Integra - Standard, A-Spec, A-Spec with Tech, A-Spec with Tech 6MT
http://www.urvi.net/forumfiles/SB/B22-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-015.PDF
TSB 23-026 - Safety Recall: Multi-Model Brake Hold/VSA Modulator Stop Sale
Applies To: 2023 Integra - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-026.PDF
TSB 23-027 - Safety Recall: 2023 Integra Brake Hold/VSA Modulator Replacement
http://www.urvi.net/forumfiles/SB/B23-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-027.PDF
TSB 24-037 - EPS Sticking and Slipping
This bulletin has been replaced by service bulletin 24-054, Safety Recall: 2023–25 Integra Steering Gearbox Assembly
Applies To: 2023-24 Integra - ALL - ALL
http://www.urvi.net/forumfiles/SB/B24-037.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-037.PDF
TSB 24-054 - Safety Recall: 2023–25 Integra Steering Gear Repair
Applies To: 2023-25 Integra (Including Type S) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-054.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-054.PDF
TSB 25-004 - Weatherstripping Loose or Not Set
Applies To: 2023-25 Integra - ALL - From VIN 19UDE4H***A016962–19UDE5G***A001268
http://www.urvi.net/forumfiles/SB/B25-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-004.PDF
TSB 25-040 - Rear Camera Displays Black and White Image
Applies To: 2023-25 Integra - Base, A-Spec Base - ALL
http://www.urvi.net/forumfiles/SB/B25-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-040.PDF
TSB 25-051 - Oil Leak at Cam Chain Tensioner Inspection Cover
Applies To: 2023-25 Integra - ALL (except Type S) - ALL
http://www.urvi.net/forumfiles/SB/B25-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B25-051.PDF
Old Sep 18, 2025 | 09:12 AM
EE4Life's Avatar
Forum Contributor
Added new TSB 25-051 - Oil Leak at Cam Chain Tensioner Inspection Cover.
EE4Life
6G TLX (2021+)
Sep 18, 2025 09:31 AM
EE4Life
ILX
Jun 10, 2023 08:54 AM
EE4Life
ILX
RDL1
3G RDX (2019+)
30
Oct 28, 2020 08:35 PM
