2006 RSX K20A3 4 cyl.
Old Jan 8, 2014 | 01:19 PM
Terry'scar's Avatar
Hello, A friend has an RSX with 2 DTC's.
One, P0135, stems from a bad fuel mix sensor (upstream oxygen sensor) which I see I can easily reach.
The other, P2647, pertains to the "rocker arm actuator control system stuck on for variable cylinder management system."
I've found pictures on this board of a clogged control system valve from the 6 cylinder engine which was successfully cleaned and returned to service.
Does anyone know where this valve is on the 4 cylinder engines?
Thanks, Terry
Old Jan 17, 2014 | 08:23 AM
BattleofXs's Avatar
2nd one sounds like vtec controller
if you check out clubrsx, they have a page that lists the error codes with solutions
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
LeVeL
Oct 18, 2015 04:19 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
