2003 Acura Rsx Base Automatic throwing Code P0134
Old Jun 21, 2019 | 06:19 PM
nivi3's Avatar
I have 2003 Acura RSX Base Automatic (USA) model. My car was throwing OBD code P0420 which indicated inefficiency with Catalytic Converter. I decided to change it along with both O2 sensors. I purchased following upstream sensor for my car which is:
Denso Air-Fuel Ratio Sensor 4 Wire, Direct Fit, Heated, Wire Length: 16.54
Part# 234-9006
The downstream sensor was NTK O2 Sensor Part #24409. The installation went fine and installer checked all connections etc. but my car now throws OBD Code P0134 which indicates that there is a problem with the oxygen sensor that is positioned before the catalytic converter and on the engine bank that houses cylinder #1 i.e. the upstream sensor.
Can you tell me if the correct part was put and what is the cause of the error and how to get rid of it?
Also, do Acura RSX and Honda Civic use same OEM Parts?
Old Jun 24, 2019 | 03:09 PM
nats007's Avatar
Part# 234-9006
Looks like the right part number from a quick search. Clear all codes and double check all connections. Ensure the wires are not touching the exhaust components.
CNC-Wiz
Jul 9, 2019 07:05 AM
Jacques226
Aug 15, 2017 06:15 AM
mnm27mnm
Mar 9, 2014 05:13 PM
tuanrich
1/2G MDX (2001-2013)
Oct 25, 2011 08:25 PM
Vim0314
Jun 5, 2008 09:10 AM
