ILX CIvic SI
Old 06-21-2018, 03:22 PM
4th Gear
chewymilk98's Avatar
ILX CIvic SI
This has been asked. But not really answered. Is there a suspension difference, any difference between my 2014 ILX, and a 2014 civic SI? Any difference at all as far as parts exchanging. My car is closing in on 93K and the stock suspension is toast. I don't really want coilovers. But unless I want to it a set of VW corrado koni inserts on the front. I'm kinda S.O.L. The coilover selection for our cars is.....Pitiful. There's a few more choices for the SI.
Bolt patterns, bolt sizes, end links. Etc. I'm asking because I have a limited window to install them. And I'd not like to be surprised by any part fitment. If no one has an answer. Could you steer me to place or person that could answer.
I've also noticed some manufacturers list the same part numbers (for an ILX and SI) and some have different numbers. That could just be internal control.
Old 06-22-2018, 08:43 AM
visi_d's Avatar
ILX SET UP
civic si set up
The main difference is circled in red. End links should be the same. 99% sure
Old 06-22-2018, 10:13 AM
4th Gear
Main difference, as in the camber bolts. Or the ABS sensor.
Old 06-22-2018, 01:25 PM
visi_d's Avatar
camber bolts
Old 06-22-2018, 02:14 PM
4th Gear
Thanks for the answers and all. But could you elaborate a little bit more. Are the bolts different sizes. Widths. Is the cam angle different. Are the holes different sizes. Most important, will Civic SI struts fit? Do I need to modify them?
Old 06-22-2018, 03:00 PM
visi_d's Avatar
Bolt sizes should be the same. Your issue will be mounting the strut to the knuckle due to the position of the holes on the strut. even if you manage to line them up, your camber will be all jacked up.
Chan_Mike
ILX Photograph Gallery
11-10-2020 09:06 AM
Preston421
ILX
04-08-2016 04:22 PM
psyfer
ILX
01-11-2016 03:40 PM
ragde556
ILX
76
11-16-2015 08:21 AM
rxj27
ILX
58
12-16-2012 07:46 PM
Quick Reply: ILX CIvic SI
